on my 68 the heater hoses drop down through the floor under the heater core, there just dangling there on there way back to the engine, isnt there supose to be a bracket holding them up? does anyone have a picture of there heater hoses i can see how there roughted? thanks john
heater hoses
Re: heater hoses
Page 1-2 and 1-3 of the service manual shows routing.
There are no brackets or clamps between where they come through the floor and the bulkhead at the front doghouse.
Re: heater hoses
thanks rod, i ordered a manual off of ebay. i should have it in a couple days, i have to do something with the hoses there pulling on the heater core that could be bad,
Re: heater hoses
The grommets in the floor hold the hoses up.
Probably time to get new grommets. I'd take carefull measurements and check the hardware store.
For a temp fix, you can prop up the hoses so the weight isn't hanging, and wrap electrical tape around the hoses so it forms a bulge that catches the top of the grommet.
Re: heater hoses
i'll check out the grommets, i'm heading to the garage to install my steering wheel, i'll take some pictures, thanks rod for your help.
