    64 & 65 rear wheel brake cylinders
    gfleduc
    gfleduc
    Number of posts : 367
    64 & 65 rear wheel brake cylinders Empty 64 & 65 rear wheel brake cylinders
    Post by gfleduc Tue May 15, 2018 10:44 pm
    This is a curiosity question - I was looking at the parts catalog for '65 brake rear wheel cylinders (I don't need any part number references)
    The '64 & '65 earlies with 3:36 rears take a smaller brake wheel cylinder (7/8" vs 1-1/16"). - Any educated guess why is that? Maybe four cylinder motors?
    Just wondering...
    Number of posts : 1778
    64 & 65 rear wheel brake cylinders Empty Re: 64 & 65 rear wheel brake cylinders
    Post by m1dadio Thu May 17, 2018 4:05 am
    What parts catalog was that? I have not seen that one.
    all the rear ones I have seen had a 13/16 piston which is hard to find  and more than three times the price of the more common 7/8 rear wheel cylinder. I found the 7/8 one to work better for the disc/drum set up.
    They used a 1 +1/8 for the front cylinder.
    Many newer parts Catalogs have been know to have errors.
    M1D
    Post by donivan65 Thu May 17, 2018 7:40 am
    ,,,,here is what I think,,,,,thats where the Early 65/Late 65 change came in April, 1965,,,,,the ones they called the Early 65 were leftover 1964 parts,,,,,,which were the 1st Chevy vans,,,,,just testing the van market and to see how their vans sold and worked and if that 64 model needed improvements,,,,so in April 65 they changed the body and brake system,,,,,and,,,,,them there SportVans got invented so they needed more efficient braking to protect the passengers,,,,,
    gfleduc
    gfleduc
    Post by gfleduc Thu May 17, 2018 12:17 pm
    1967 Catalogue
    The 3.36 rear axle is the one seem to me as standing out - like I said just a curiosity question why would the other ratio rears use a different size.
    64 & 65 rear wheel brake cylinders Wc10
    FWIW - my '65 12 bolt rear appears to have the original cylinders @ 1-1/16"
    Both the front & the rear right side have the same casting number.
    Both the front & the rear left side have the same casting number.
    64 & 65 rear wheel brake cylinders Wheel_10
    (Casting P/N)
    Post by donivan65 Thu May 17, 2018 8:05 pm
    The higher gear rear ends use the larger 2 1/2" brake shoes,,,
    gfleduc
    gfleduc
    64 & 65 rear wheel brake cylinders Empty REar Brake shoes
    Post by gfleduc Fri May 18, 2018 1:52 am
    It did get some 2-1/2" shoes, test install was lousy - I suspect the prior owner had 2" kit; the spring pins that go through the backing plate seem a tiny bit too short,
    Post by m1dadio Fri May 18, 2018 10:35 pm
    Stranger than dirt?
      Current date/time is Fri Apr 26, 2024 8:36 am
