+6
VCVCSmiley
Jim_Rockford
kookykrispy
1966G10
10 posters
    First Gen Rear Wheel Cylinders
    1966G10
    1966G10
    Number of posts : 138
    Registration date : 2009-10-14
    First Gen Rear Wheel Cylinders Empty First Gen Rear Wheel Cylinders
    Post by 1966G10 Tue Jun 23, 2015 12:46 pm
    Hey guys, Working on rebuilding my brakes on my 66 Sportvan. I redid the fronts already. But had a question.
    The front wheel cylinders were about $13 a piece and the rears are like $35 from Napa. Is just how they are or am I looking at something wrong?
    kookykrispy
    kookykrispy
    Number of posts : 1533
    First Gen Rear Wheel Cylinders Empty Re: First Gen Rear Wheel Cylinders
    Post by kookykrispy Tue Jun 23, 2015 2:15 pm
    If you can even find them consider yourself lucky
    Post by Twinpilot001 Tue Jun 23, 2015 2:20 pm
    Good ol =Rockauto.com has the rears fron 13 bux up to 38.00 or there abouts!
    Number of posts : 1412
    Post by Vantasia Wed Jun 24, 2015 4:08 am
    About right, just had all 4 of mine done and a local supplier charged $28 fronts and $35 rears but supposed to be top quality ones. Hoses were harder to find, no locals including Napa had them, we had to order Raybestos brand from Rockauto, about $20 each hose and they still say made in China on them....
    Jim_Rockford
    Jim_Rockford
    Number of posts : 25
    Registration date : 2015-06-21
    Post by Jim_Rockford Wed Jun 24, 2015 7:16 am
    Can you find rebuild kits? Unless the bores are pitted you can rebuild em way cheaper
    1966G10
    1966G10
    Post by 1966G10 Wed Jun 24, 2015 10:02 am
    Yeah the local auto store can order them, just seemed like a lot between the fronts and the backs but its fine just wanted to check. The hoses were a pain to find like you said. I had to have them special order them.
    VCVCSmiley
    VCVCSmiley
    Number of posts : 73
    Post by VCVCSmiley Thu Jul 02, 2015 5:08 pm
    The rears are an odd size bore (as I was told), so the rebuild kits for them are almost as expensive as replacements.
    Number of posts : 1778
    Post by m1dadio Thu Jul 02, 2015 5:28 pm
    rear wheel cylinders for 1st and 2nd gen vans are an odd size. they are 13/16 and fit only the G10 vans and 67 to 69 olds 442.
    thats why they are expensive (suply and demand)
    I went with the   UP37024    7/8" wheel cylinder used on every other gm vehicle from 64 to 1989 (and used on the 4 cylinder van 64 and 65.  Works great and way cheeper (suply and demand)
    Bolts right in.
    First Gen Rear Wheel Cylinders Dscn0510
    m1d
    Post by Joe Van Fri Jul 03, 2015 2:17 am
    I found the brake hoses available at "carquest auto parts" in stock for my 66 GMC van no problem along with all the other brake parts you will need..!!!... Very Happy
    rarechev!
    rarechev!
    Number of posts : 4
    Registration date : 2013-12-10
    Post by rarechev! Fri Jul 03, 2015 7:12 am
    m1dadio wrote:rear wheel cylinders for 1st and 2nd gen vans are an odd size. they are 13/16 and fit only the G10 vans and 67 to 69 olds 442.
    Bolts right in.
    m1d
    x2 I used 70 chevelle rear cylinders 3 years ago, bolt in and have worked fine.
    ditdater
    ditdater
    Number of posts : 590
    Post by ditdater Mon Jul 06, 2015 2:45 pm
    Bolts right in.
    are you saying that if I have a stock orig. 65 ,153 four cylinder , that's the part number I look for up37024 ? would front be same as 6 cyl. van ? thanks danny
    m1d
    Post by m1dadio Mon Jul 06, 2015 5:54 pm
    the wheel cylinders for 1st gen came in 7/8", 13/16, 1" and 1 and 1/16" depending on year and axle ratio.
    64 and early 65 (small grill) all used 7/8".
    there was three different bore sizes on the fronts, Idon't know which was yours.
      Current date/time is Sun Apr 28, 2024 10:42 am
