    DELCO Wheel Cylinders 1st Gen
    gfleduc
    gfleduc
    Number of posts : 367
    DELCO Wheel Cylinders 1st Gen Empty DELCO Wheel Cylinders 1st Gen
    Post by gfleduc Tue Jun 26, 2018 9:46 am
    Hi Gang,
    Looking for some 1st Gen numbers.
    If you have your either your front or rear wheel cylinders visible, can you share what casting number & size is on it. Also If you have the original installed position & rear axle ratio that would be a valuable reference.
    I am hoping the guys who converted to front disc may have the pulled parts readily available.
    If you just want to send me a photo that is good - gfleduc@hotmail.com
    Thank-you in advance
    Gary
    example:
    DELCO Wheel Cylinders 1st Gen Wheel_10
      Current date/time is Sun Apr 28, 2024 12:08 am
