    What Headers Will Fit?
    The Blue Box
    The Blue Box
    Number of posts : 20
    Registration date : 2016-12-08
    What Headers Will Fit? Empty What Headers Will Fit?
    Post by The Blue Box Fri Oct 13, 2017 6:20 am
    Ok so l've heard mixed things about header fitment in the econolines.  I recently picked up a built 200 to replace the worn out 170 and would like to have headers as the motor has a cam, bigger valves and a 2 barrel weber conversion.
    Anyone know if theres a header that clears the doghouse?or am i gonna have  to do some cutting.  This is on a pre 65 van.
    Number of posts : 2086
    What Headers Will Fit? Empty Re: What Headers Will Fit?
    Post by Seth G Fri Oct 13, 2017 8:44 am
    I don't know if there some that fit without cutting. But I know the common $200 stainless headers on Ebay don't quite fit in the doghouse and require either modification of the headers or the doghouse. Stanyon found this when he installed them.
    You can see in the first pic in this thread where he modified the doghouse for clearance. You won't have the starter clearance problems he had though. He was using an 80's low mount starter 200 block.
    https://vintage-vans.forumotion.com/t47590-e_bay-headers
    The Blue Box
    The Blue Box
    Post by The Blue Box Fri Oct 13, 2017 9:51 am
    Seth G wrote:I don't know if there some that fit without cutting. But I know the common $200 stainless headers on Ebay don't quite fit in the doghouse and require either modification of the headers or the doghouse. Stanyon found this when he installed them.
    Are those the single or dual outlet ones?
    Canada17
    Canada17
    Number of posts : 49
    Registration date : 2016-03-21
    Post by Canada17 Fri Oct 13, 2017 10:33 am
    I have a new set of single outlet headers for a 200 I'm selling right now. I didn't use them because they would require approx 1" of floor to be cut out and the doghouse to be pushed out at the bottom. PM me if you would like more info. My truck is done and I'm clearing out parts.
    Post by Seth G Fri Oct 13, 2017 11:44 am
    Those are the dual outlet ones.
      Current date/time is Fri Apr 26, 2024 1:12 pm
