    headers for 200
    headers for 200 Empty headers for 200
    Post by Guest Wed Sep 21, 2011 4:34 pm
    im thinking of putting headers on my 200 ci. is it worth the expense?
    SDEconoTruck
    SDEconoTruck
    Number of posts : 310
    headers for 200 Empty Re: headers for 200
    Post by SDEconoTruck Wed Sep 21, 2011 4:50 pm
    What rpm range Steve?
    If you want off-idle torque the stock exhaust
    manifold provides the necessary back pressure
    to maintain efficiency. If you want peak power
    at higher rpm's then headers will provide that
    for you. Of course you can get good off idle
    torque with headers but several other things will
    be needed to be done to the engine...
    Post by Guest Wed Sep 21, 2011 8:00 pm
    if you do get headers have them Jet Hot Coated. Headers put out 900-1000 degrees of heat but when jet hot coated they only put out 450-500 degrees thus less heat in the doghouse
    Number of posts : 648
    Post by Rayallen Wed Sep 21, 2011 8:10 pm
    Im right there with you, started a thread a few weeks ago about maybe buying some Clifford Performance headers. They are not cheap.
    I am wanting to put headers on my 65 200ci for the sound and a little more horse power.
    If I could get a decent sound out of my manifold with a better exhaust Id probably stay with that, but at the moment it sounds like shit.
    Is there a good setup using the stock manifold that will give you the hot rod sound?
    Post by Guest Wed Sep 21, 2011 8:25 pm
    you can go with a split exhaust and use Delta Force single chamber racing mufflers and get a pretty god sound but you can't beat those clifford headers
    Number of posts : 2011
    Post by Barnabas Thu Sep 22, 2011 8:21 pm
    I had a Œ65 with a 200 and Clifford Headers. The biggest thing I remember was that I could up shift a little early and the engine did not bog down. It did sound really cool.
    I remember notching the floor flange that stuck into the dog house and hammering the dog house a little out of shape to make them fit.
    That was 25 years ago!!
    Post by Guest Thu Sep 22, 2011 8:26 pm
    Clifford headers fit on a 200 now and do not require any mods to the dog house
      Current date/time is Tue May 07, 2024 12:18 am
