Millwright71's A108
Millwright71's A108
Post by millwright71 on Wed Jan 02, 2013 11:21 am
I never really started a thread about my 67 A108, so here it goes. My Dad had a 67 econoline supervan when I was a kid, he never really drove it, but it sat in our back yard. I used to sit in it and mess around like I was driving.
A friend of mine at work had a restored econoline pick up and we always talked about how I would like to have a flat nose van, I am not a Ford guy, so I was looking for a Dodge, or a Chevy.
He told me about a Dodge panel van on Craigslist in my hometown, so I contacted the guy, heard it run, and had to have it! It is a 318 3 speed, 50K miles. Here it is the day I bought it, approximately Feb 2012.
Number of posts : 2041
Re: Millwright71's A108
Post by dodge man on Wed Jan 02, 2013 11:39 am
LOOKS GREAT, DO YOU HAVE MORE PICTURES? WE LOVE TO LOOK AT PICTURES
Pictures
Post by millwright71 on Wed Jan 02, 2013 11:57 am
I took alot of pictures while I have been working on the body. I drove it alot for the first couple months just to get a feel for what it needed, and what I wanted to do to it. I have welded in all new sheet metal wherever there was rust, mostly along the rockers, and front fenders. The rear corners were in bad shape, as well as the rear roll pan.
[/url
[url=http://www.servimg.com/image_preview.php?i=22&u=17740080]
Post by dodge man on Wed Jan 02, 2013 12:10 pm
looks real nice, mine has some bubbles in the paint on the rear corners, i'll bet its rust starting to come through, the paint on mine is real thin, it was a shity job just so he could sell it, when ever it gets bad i'll fix it and primer the hole van,
Rust
Post by millwright71 on Wed Jan 02, 2013 12:45 pm
The rear corners tend to rust where the floor lap joints to them. Also, it is worth checking into how much dirt has accumulated inside the rear roll pan. It was amazing how much sand, dirt, and gravel I got out of it with the shop vac when I pulled the rear bumper, and it's brackets out of the way. I stripped the entire body down to bare steel, then I put several coats of etch primer, high build, and finally epoxy primer sealer on her after block sanding that body for what seemed like weeks.
Number of posts : 1880
Post by savage on Thu Jan 03, 2013 3:22 am
I have seen Tom's van. Its Better than New Cool
Number of posts : 3022
Post by RodStRace on Thu Jan 03, 2013 8:15 am
I second the dirt in the pans!
Also, pull the little triangle plates inside and get all the dirt out of the back of the dogleg!
Post by millwright71 on Thu Jan 03, 2013 2:54 pm
Thanks for the compliment Savage! We still need to get together for those parts for my Chevy, maybe even give you a hand on the big block project? Rod, my doglegs were so rusted out, the dirt done already fell out! Lol.
Tom.
Number of posts : 8015
Post by dix on Thu Jan 03, 2013 4:01 pm
surplus supply has the dog legs if you need them look under a- links page..
Post by millwright71 on Thu Jan 03, 2013 4:14 pm
They do have them, and they are heavy gauge metal, and they fit really well. I bought at least one of every panel they make for the A's. I highly recommend them.
Post by dodge man on Thu Jan 03, 2013 4:19 pm
thanks thats good to know, i give mine a year and the rust will be comming through
Post by dodge man on Thu Jan 03, 2013 4:39 pm
i just checked out surplus supply they have a lot of panels have any of you used a do it yourself fuel tank sealer or liner?
Post by dix on Thu Jan 03, 2013 5:39 pm
here is what i used with confindence
Post by dix on Thu Jan 03, 2013 5:40 pm
Post by dodge man on Thu Jan 03, 2013 5:44 pm
thanks dix,
Progress
Post by millwright71 on Fri Jan 11, 2013 3:03 pm
I have been working on the floor lately. I got the seams coated with rust bullet some time ago, I followed the manufacturers instructions and covered the entire floor including the passenger area with a do-it-yourself spray on bedliner product. It looks really good. I am hoping it does double duty, sound deadener, and a rust preventative when I cover the floor later when I get to the interior. Pics to follow!
Pics
Post by millwright71 on Fri Jan 11, 2013 3:30 pm
The floor with the rust bullet
After the bedliner
Post by dodge man on Fri Jan 11, 2013 3:37 pm
looks really good tom, i used a bed liner on mine from a rattle can, then insulation then 1/4'' plywood its real quite
Number of posts : 726
Registration date : 2012-09-26
Post by NoBiggie on Fri Jan 11, 2013 4:18 pm
Looks great!
Number of posts : 866
Post by wylee on Sat Jan 12, 2013 2:35 am
nice.........
Post by dix on Sat Jan 12, 2013 3:42 am
so what's next.
Post by millwright71 on Sat Jan 12, 2013 4:34 am
I am currently cleaning up the engine, replaced all of the gaskets, New valve seals, and paint. I am putting a new clutch kit in her, then having the old trunion joint removed from the driveshaft in favor of a slip yoke and universal joint.
Post by dix on Sat Jan 12, 2013 5:07 am
I have my part number wrote down but you should use a u joint that is very popular and you can remember like 1970 duster or the same as used in the rear . so later on it does not become hard to find. you can also buy a spare now nad never worry about it. the drive shaft should cost around $200.00 but a great up grade.
Post by dodge man on Sat Jan 12, 2013 7:26 am
let us know who does your drive shaft, i'll need to have mine done when i rebuild the trany,
rebar
Number of posts : 151
Post by rebar on Sat Jan 12, 2013 12:23 pm
dix wrote:I have my part number wrote down ... you can also buy a spare now nad never worry about it.
Good idea Mr dix. You might be able to fit a couple of them into the battery box, or just carry the old driveshaft under the passenger seat, next to the come-along... While towing tandum U-hauls on cross-country trips they only last about 2,500 miles.
    Current date/time is Sat Jun 23, 2018 10:14 pm
