    water pump pulley
    mariovan
    mariovan
    Number of posts : 33
    Registration date : 2015-02-11
    water pump pulley Empty water pump pulley
    Post by mariovan Sat Apr 25, 2015 2:55 pm
    Trying to remove the pulley to get access to the bolts and remove the water pump. but no luck.
    is there a trick to doing this?
    200 engine
    water pump pulley Empty Re: water pump pulley
    Post by Twinpilot001 Sat Apr 25, 2015 3:11 pm
    no isnt!! likely only rusted on or wp was painted & pulley installed while paint was wet!! slap it lightly with a wood block or compothane hammer.
    mariovan
    mariovan
    Post by mariovan Sat Apr 25, 2015 4:57 pm
    hey thanks, I got it out.
    mariovan
    mariovan
    Post by mariovan Thu Apr 30, 2015 12:15 pm
    ok, working on the same area, now the water outlet/thermostat housing. I got a better one for the engine with gasket and new bolts.
    Do you guys recommend to put a little of the thread lock on it or just leave and torque to specs?
    Number of posts : 2086
    Post by Seth G Thu Apr 30, 2015 12:26 pm
    Put some rtv on those bolts. Permatex sells one in a small grey tube just for that purpose.
    Das Boot
    Das Boot
    Number of posts : 76
    Post by Das Boot Fri May 01, 2015 6:53 am
    +1 on the RTV / sealer... the lower bolt on the water pump goes straight through to the water jacket.
    mariovan
    mariovan
    Post by mariovan Fri May 01, 2015 10:10 am
    I have some of the blue permatex, will that be OK.
    aiming for this weekend to take it for a spin again.
    what do you guys recommend to put on the water outlet gasket?
    Number of posts : 1412
    Post by Vantasia Fri May 01, 2015 12:32 pm
    Permatex
    http://www.permatex.com/products-2/product-categories/gasketing/gasket-makers/permatex-water-pump-thermostat-rtv-silicone-gasket-detail
    Make sure the thermostat is seated and not pinched under the housing ear, this happens many times and leads to a crack in the ear and a leak, seen (and done!) a few.  Napa sells stick-on gaskets that hold the stat in place and only need a sealer on the top.  Read your manual and use a torque wrench, its 25-28 ft-lb on GM's, should be about the same on a FoMoCo, very easy to overtighten and strip or break the ear off the neck.  But you know that....
    mariovan
    mariovan
    Post by mariovan Fri May 01, 2015 2:58 pm
    thank you all.
    I hope my econovan gets a taste of the street over the weekend.
      Current date/time is Sun May 19, 2024 6:38 am
