    Water Pump ** Tall vs Short
    PolarBear2
    PolarBear2
    Number of posts : 183
    Water Pump ** Tall vs Short Empty Water Pump ** Tall vs Short
    Post by PolarBear2 Fri Jan 30, 2015 4:55 am
    Which is better for what and why? My Crate Engine has a Tall Water Pump and I have a 4 row radiator I'm putting in the stock location. Looking at different pulley set-ups/combos at Summit. Want to add Vintage Air down the road, just an alt to start with.
    Number of posts : 512
    Water Pump ** Tall vs Short Empty Re: Water Pump ** Tall vs Short
    Post by pan58head Fri Jan 30, 2015 5:54 am
    If you have the extra 1" stay with the long water pump, almost all aftermarket ac kits are set up for long water pump. Plus using a short waterpump puts the alternate over the heads
    Post by Twinpilot001 Fri Jan 30, 2015 9:02 am
    short wp= all= were  in all tears from 1968/69 down. that was due to the heads =NOT!! being cast & drilled for the mounting positions for accessories! in 68 came the  mounts =long wp  & accessories on all chev engines V-8's!Mounts  are still  available for the short wp's  from many  places-summit jegs & others too! -- alternators can (SW=P's) be mounted below engines, all a/c parts also- ps pumps & such too- i have & use short pumps.Due to im still using the fulie heads - readily avail. around here! And i do like the cleaner look  for the top of engine too! Pop the doggie box &   get that =WOW!! Factor!  affraid cheers
    many have forgotten  in 1970 up =after all our car mfg's were all made to get power down &  emissions up!! Highet compression ratios  were a thing of the past too!!  Took many, many years  for things to develope to what we have again today in terms of Horsepower from the car mfg's.!! Finally - some performance !! Not just loud sounds(radios & tunes!!) coming from cars any longer!! cheers
    PolarBear2
    PolarBear2
    Post by PolarBear2 Fri Jan 30, 2015 1:39 pm
    The difference between the two is only an inch? I'll stick with the tall one and see where it gets me.
    Thanks Much
    Number of posts : 1388
    Post by wideload Sat Jan 31, 2015 4:44 am
    Water Pump ** Tall vs Short Long1010
    Water Pump ** Tall vs Short Short110
    PolarBear2
    PolarBear2
    Post by PolarBear2 Sat Jan 31, 2015 5:31 am
    Nice, thanks Mike.
    Rick's 66 Chevy Van
    Rick's 66 Chevy Van
    Number of posts : 331
    Post by Rick's 66 Chevy Van Wed Jan 27, 2021 5:15 pm
    Hey man where did you get your water pump and do you have a link on replacing it ?
      Current date/time is Fri Apr 26, 2024 9:24 pm
