water pump question
Bear
Number of posts : 849
water pump question
Post by Bear on Mon Jun 23, 2014 10:27 am
useing cross flow raditor what water pump i need long neck or short
Number of posts : 11492
Re: water pump question
Post by donivan65 on Mon Jun 23, 2014 10:52 am
,,the length determines where the fan belt pulley sits,,,,,,you need it to be in line with the alternator and crankshaft pulleys,,,,,don't change it.......
Number of posts : 766
Post by panelmanrd on Mon Jun 23, 2014 2:27 pm
depends on which pulleys you have, got any pics of your crankshaft pulley?
Bear
Post by Bear on Mon Jun 23, 2014 2:31 pm
i,m replaceing the 307 with 4 bolt mane 350 i though the long vrs short neck water pump was based on what raditor set up you run. i,m guessing i,m wrong ad my stock short neck pump will serfise ??
    Current date/time is Thu Jan 18, 2018 9:32 am
