    Water pump 65 g10 six cylinder
    rfergnes
    rfergnes
    Number of posts : 39
    Registration date : 2013-09-15
    Water pump 65 g10 six cylinder Empty Water pump 65 g10 six cylinder
    Post by rfergnes Fri May 23, 2014 2:52 pm
    Hey,
    Anyone know what size water pump to get for a 65 6 cylinder? Oriellys has two different shaft sizes available
    Thanks
    diamond dave
    diamond dave
    Number of posts : 565
    Water pump 65 g10 six cylinder Empty Re: Water pump 65 g10 six cylinder
    Post by diamond dave Fri May 23, 2014 3:08 pm
    I wouldn't think that the shaft size would matter on the water pump. as long as the end of the shaft that the fan fits on is the same. just make sure the other dimensions are the same, and if all else fails, get em both, and bring back the one you don't use.
    Post by donivan65 Fri May 23, 2014 6:30 pm
    they have different shaft heights for different pulleys ,,, you need an Airtex 895,,,and that should be the 4 3/8" shaft,,,,,but take yours off,,,see how much the flange sticks out from the base,
    Post by donivan65 Thu May 29, 2014 3:32 pm
    a new waterpump at Autozone is a Duralast BWP-386,,,,,,$27.99
      Current date/time is Tue May 07, 2024 9:40 am
