2nd Gen water pump "Long" or "Short"
Post by Joe Van on Sun Sep 21, 2014 6:25 am
I would like to know if the 2nd gen V8 Van's came with a "Long" or "Short" water pump..??.. I just bought a 2nd gen fan shroud and clutch fan to install in my Van once the weather cools off....Thanks... Smile ..
Re: 2nd Gen water pump "Long" or "Short"
Post by Twinpilot001 on Sun Sep 21, 2014 6:50 am
come on !! JOE!!!!!!!!! You should know that!! My 67 is =short =yet as a long pump & heads (drilled) for accessories-I believe is better = as allows for more "aftermarket" accessories mountings! I have kept the short pump on my build & it takes some searching- for mounting stuff -yet is available!! hehe =maybe ur a ford:lol!: lol! lol! guy?? affraid
I keep thinking the "LONG" pump started in about 1968??
Post by Joe Van on Sun Sep 21, 2014 7:35 am
Well if they all defiantly came with a "short pump" 68-70 also then I have to change all my pulleys,,, Alt.bracket & water pump before I can use my Clutch Fan & 1968 Factory Shroud..!!!.. Evil or Very Mad ..................3 steps up the ladder 2 steps back down... Smile ...
Post by Twinpilot001 on Sun Sep 21, 2014 8:56 am
not saying 67-70 did-yet my origional 67 did!! i may be mistaken -but i believe the car line changed to long pumps about 68?/ yet maybe 70?/--yes i did same thing -get the pulleys fron skip white on ebay -cheapest u will find!! cheers
Post by Twinpilot001 on Sun Sep 21, 2014 9:04 am
Post by Twinpilot001 on Sun Sep 21, 2014 9:06 am
Post by Twinpilot001 on Sun Sep 21, 2014 9:08 am
joe-u realize there is also an alu. bracket kit for mounting the alternator on bottom of engine?
Post by Joe Van on Sun Sep 21, 2014 9:58 am
WOW..!!!..Twin thoes are some great prices but I sort of want to stay with the stock steel ones... I did all that billet stuff on my 41 Willys and I spent more time cleaning it than I did driving it.!!!..I am going to get the tape measure out and see how much room I have I know the shroud will fit since its a 1968 motor box but not so sure on the clutch fan it may be to close to the radiator for the shroud to actually work and pull the air in.....I may just get a regular 6-7 blade fan and bolt it directly to the pump and see if that will work before I have to go buy all new pulleys and brackets "Again"...and running the alt down below means redoing the wiring "Again"..!!!.. Smile .. lol! lol!
Post by Twinpilot001 on Sun Sep 21, 2014 11:27 am
I may part with my stock metal pulleys?? and if you want ill give you the old & new part #'s for the clutch & oem fan that came on mine!!?? ill add in looking @ that shroud in ur pix there? my V-8 oem one is different!! and remember i have a crossflow raidiator-oem. im thinking the one in pix is for a 6 cyl engine ?? or? mayber downflow raidiator?? Pix of the V-8 stuff is in the forum somewhere too- maybe dix or gman posted them long ago? cheers
Post by Joe Van on Sun Sep 21, 2014 2:43 pm
I was told the 6 cylinder Van's did not have a full fan shroud is that correct..???..I know I have to make brackets for the shroud because my radiator is not a cross-flow but hang on to them pulleys just in case if I cant get the long water pump style ones to work I will buy them from you...
Post by Twinpilot001 on Sun Sep 21, 2014 6:22 pm
ok understand- yet i dont know about the downflow stuff its all 6 cyl. affraid U gotta V-8!!
Number of posts : 1878
Post by savage on Mon Sep 22, 2014 4:43 am
Pic from Joe(Wookke on VCVC)
Post by Joe Van on Mon Sep 22, 2014 5:10 am
"Thank's" For the Reply Tom..!!!.. Is the smaller one for a 6 cly.??.. I seen a V8 shroud for sale here and it looks like the one I have on the left of your picture...Do you think I can get away with useing the long pump set up on a factory 2nd gen shroud and clutch fan before I tear it all apart..I know I will have to build some brackets because of the 3 core downflow radaitor set up..Do you know if any V8 Early Chevy (68-70) came with a long water pump set up or were they all short.???.. I had to go with the short set up on my Willys.!!!.. I Just got off the phone with Car Quest Auto and there is almost 2 inch hight difference between the "Long" & "Short" water pump.. affraid ...
Number of posts : 1340
Post by wideload on Mon Sep 22, 2014 6:50 am
Joe maybe this will help.
Long
Short
Post by Twinpilot001 on Mon Sep 22, 2014 6:57 am
long water pump style was changed from short style when chev recast the heads for the mounting bosses holes on front of heads!! All accessories were then mounted from those areas. That design was a carry over from the 1965 396 chev engines as the heads accessory bolt holes were done to the big block engines then.
Post by savage on Mon Sep 22, 2014 7:03 am
Joe, Yes the short ones for a 6. heres a pic of my 68 G-20 from Cail with the 307,& I guess stock water pump(???) the shroud was cut down 1 &1/2 inches(Why??)in width,and I "think" its got a flex fan on it. Now its got the right shroud & fan on it,but its not here for pic. Hope it help.
Post by Joe Van on Mon Sep 22, 2014 12:37 pm
Thanks Guy's after seeing Tom's picture and makeing a few calls looks like the early chevys came with a "Short Pump" so I will ditch the clutch fan and go with a regular fan and bolt it to the pump with a small spacer that should make up the 2 inch difference..I see on Toms photo the alt is mounted under neath also I am not going to try to hunt all the right brackets and pullys and change everything around so I will work what I have useing the factory shroud and a regular fan... Very Happy ...
    Current date/time is Tue Apr 24, 2018 6:59 am
