+8
ChevyVanMan1
mo_1040
12 posters
    Door adjustment
    Door adjustment Empty Door adjustment
    Post by Guest Mon Apr 06, 2009 4:47 pm
    How do you adjust the gap between the doors?
    I changed the 2nd gen doors that were on the side to the rear and the gaps are off, ALOT. They sit pretty close to the body and have a large gap in between them, so did the original doors. I moved them to the side, but the bottom on both doors are pretty rotted out. So I'm looking for some panel doors for it.
    Any help would be great.
    Door adjustment Empty Re: Door adjustment
    Post by donivan65 Mon Apr 06, 2009 6:59 pm
    Did you move the hinges with the doors?
    Post by Guest Mon Apr 06, 2009 7:34 pm
    No, just the doors. But the other doors fit the same way.
    Post by donivan65 Mon Apr 06, 2009 10:37 pm
    If all doors don't fit right, then the hinges are bent,,,,,,
    Post by Guest Tue Apr 07, 2009 5:29 pm
    Thats what I thought.
    Post by donivan65 Tue Apr 07, 2009 7:38 pm
    Probably the outside parts need to move in towards each other. So maybe take 2 blocks of wood, put them close to the hinges and carefully close the door slowly. The idea is to bend the body hinges in a little by squashing a board between the door and the door frame,,,,,or take them off and straighten them,,,,,,or use a come a long ,,,,,,,,,,,My door opening is 50" at the upper hinges. I would have to guess over the years, the body flexes back there against the doors and bends the hinges outward. I would think like a 1/4" gap around the doors is right,,,,and maybe 3/8" between them.
    Post by Guest Tue Apr 07, 2009 8:02 pm
    Thanks I will try that.
    Post by Guest Wed Apr 08, 2009 6:06 am
    I took my hinges and cut them vertically. Then added a 1/4" gap by tack welding them, hanging the doors to check the gap all around. Then took doors off van and welded up gap on hinges from the cuts made and ground all welds, painted hinges. My doors now have a nice 3/8" gap all around and the door gaskets touch the jamb like new. I did the board trick only to find the doors return back eventually. I think the sheetmetal in the door shell is stressed over time. I chose to widen the hinges and leave the door alone. Seems to be fine 10 years later. Hope this helps.
    Post by Guest Wed Apr 08, 2009 6:17 am
    My gap is actually 3/16", not 3/8". Sorry about that.
    Post by donivan65 Thu Apr 09, 2009 7:33 pm
    So you cut the door side hinge close to the pin and welded it back to move the door over and the gaps look good?
    Door adjustment Hinge_11
    Post by Guest Mon Apr 13, 2009 6:09 am
    Yes! My problem was the rear and side doors had a tapered gap that grew larger towards the bottom. My remedy has made the doors equally gapped all the way down the center and the gap along the body. It is time consuming, but it depends on how much work you want to do and how bad you want your old van to look like a new one.
    Post by donivan65 Mon Apr 13, 2009 4:53 pm
    But if a guy has a welder and band or chop saw laying there, it's a good way to fix the problem. Probably a van with misadjusted door gaps was driven on rough roads and the body flexing caused the problem over the years. We just put up ideas so everyone can choose what is right for them.
    Post by Guest Mon Apr 13, 2009 4:59 pm
    I can tell you one thing........whoever worked on THIS van was a hack!
    Post by G-Man Mon Apr 13, 2009 7:37 pm
    mountainkowboy I think that same guy hit all our vans threw the years
    mo_1040
    mo_1040
    Number of posts : 645
    Post by mo_1040 Mon Apr 13, 2009 7:52 pm
    I remember when I got my van. The guy was bitching that it took him "hours" to get the back doors lined up. The way he was describing it made me afraid to even touch them. Of course I have first gen door on my 67.
    Number of posts : 1046
    Post by VANagain Wed Feb 08, 2012 11:04 pm
    Has anyone tried bending the hinges to adjust the gaps? That was the recommendation of a bodyman. You'd obviously have to use a torch to heat the metal but that would ensure it would bend where you want it to. Then, which part to bend? The one that's already curved, I would think.
    I thought for sure there'd be a way to shim them but there ain't.
    This is very common. I see it on most of the early Chevy vans. Does anyone have one with cargo door gaps that ARE even?
    ChevyVanMan1
    Number of posts : 425
    Post by ChevyVanMan1 Fri Feb 10, 2012 10:21 am
    Good luck with that. I'm not much help past using shimms. Dense plastic is good as it doesn't hold water. My rears have something over a half inch gap. Seems to be so normal with our van I wonder if it's just that wa from the factory--nobody sold these for van shows. Still closes and locks okay so I'm not motivated to fix. Nonetheless, please report what did work for you. Thanks much!
    Number of posts : 2067
    Post by sasktrini Fri Feb 10, 2012 11:57 am
    Measure your door jambs for squareness first. Measure your doors for squareness too.
    I had to use a ram on a door jamb to close a gap.
    Post by Digz Fri Feb 10, 2012 2:19 pm
    Bending the hinge might help , but you would have to stretch or shrink the curved part (re-radius it). If I was going to be that fussy I'd probably rework the edges of the doors themselves if they latched and sealed okay.
    Post by Twinpilot001 Fri Feb 10, 2012 4:02 pm
    Inspect, inspect & Inspect = the doors where hinges bolt in. possibly-?? wind or an accident has bent the hinge mount areas inside the door ?? Being in the body work for some time in my past life ive never had to bend a hinge. Ever!Always was another problem that wasnt forseen.
    Number of posts : 1383
    Post by chester42 Fri Feb 10, 2012 5:13 pm
    On my rear doors I had to ad a strip of 1/8" to gap. 3/16th at top and wider (3/8") on bottom to get a good 1/8" all around both doors. Looks better then factory now.
    Post by chester42 Fri Feb 10, 2012 5:59 pm
    The end results are a good straight gap.
    Door adjustment Gedc0435
    Post by Twinpilot001 Fri Feb 10, 2012 6:44 pm
    [i]Good Fix - nice results!! Thats usually the ways.
    Post by VANagain Sat Feb 11, 2012 12:03 pm
    I think I figured out the cause of this gap! I was looking at my rear doors. The gap is so big that the latch doesn't even reach the "striker" on the other door!
    I bet most people are like me and removed the straps that keep the doors from opening all the way up. They're not needed, right, because the hinges have a built-in stop that keeps the door from hitting the van.
    Door adjustment Img_2910
    So, you know the old trick of adjusting a door by closing it against a block of wood in the hinge area? Hinges are tough steel but this trick works because you've got the leverage of the door's width to help you bend things. Well what do you think is happening every time we open a cargo door all the way and it hits that stop?! Same thing. A lot of leverage being applied to the hinges!
    Go out and push a door against the stop. Just by pushing with one hand you can see the force being applied to those two hinges and the door frame they are bolted to. So picture 45 years of this, along with the occasional door-catches-the-wind like TwinPilot said. And never is any force applied in the opposite direction.
    So here's what I'm going to try: I'm guessing that the 1/4" thick steel hinge didn't bend, it's the thin steel of the body that it bolts to. Take apart a spare hinge and take the straight part (that attached to the body) and weld it to a nice long steel bar. Now it can be bolted in place and it should be easy to "encourage" the mount back to its original angle. Undo the years of impacts by pushing back the other way. It would take a lot of time removing the tool and testing the door, but I am convinced this is the way to fix this problem.
    What do you think?!
    Post by VANagain Sat Feb 11, 2012 12:05 pm
    I should mention, I've got a whole set of rebuilt hinges that will be swapped out during the body work phase. You can see how worn out the hinge is in this photo. I will test the fit with the new hinges before proceeding with my plan.
      Current date/time is Thu May 09, 2024 1:02 pm
