only two Springs
+4
got2bowl
8 posters
Decoding my vin
got2bowl- Number of posts : 55
Registration date : 2010-12-10
- Post n°26
Re: Decoding my vin
Leaf Springs
only two Springs
only two Springs
- Post n°27
Re: Decoding my vin
- Post n°28
Re: Decoding my vin
in looking @ pix = to me?? it appears someone used a surburban chassis & put the body on that?? could be a blazer? yet long wheelbase! Crossmember for trannys looks factory! whats the width of the springs front & rear? 2 & 1/2 or 3"??
To my ol;d knowledge -Gm did NOT build any 4 x 4 vans till after mid 70's. Ill correct myself here - never did build a 4 x 4 van -Factory-all were conversions -Ford did i do believe yet not GM.
- Post n°29
Re: Decoding my vin
My Vin says suburban
- Post n°30
Re: Decoding my vin
Both 3 inches wide
- Post n°31
Re: Decoding my vin
bet u have a surburban chassis with the van body installed on it . whats it titled as? likely the year of the van body!! 3" springs are fit to the blasers & surbs.
- Post n°32
Re: Decoding my vin
Why would the vin suburban?
- Post n°33
Re: Decoding my vin
why would the vin say suburban ?
GMman- Number of posts : 798
Registration date : 2014-10-14
- Post n°34
Re: Decoding my vin
Vin numbers were a little flakey for identifying options on vehicles until the NHTSA standardized all VIN numbers in 1981.
- Post n°35
Re: Decoding my vin
- Post n°36
Re: Decoding my vin
- Post n°37
Re: Decoding my vin
Isn't there a VIN number stamped into the metal somewhere around the engine cover on a 2nd gen van? Even if it is a home brewed 4x4 it looks like a decent job of it. That transfer case is a little old school but they were favored for a simple conversion. Stretching my memory but looks a lot like a New Process 203 all gear driven? They were easy to mount. It would not be completely unusual to find a little Title jumping happening on these old girls also.
- Post n°38
Re: Decoding my vin
I'll look for welds tomorrow and not sure what you mean about notching but I'll take a closer look at that to.
Last edited by got2bowl on Tue Nov 18, 2014 8:20 pm; edited 1 time in total (Reason for editing : Misspellings)
- Post n°39
Re: Decoding my vin
- Post n°40
Re: Decoding my vin
I'll look at that tomorrow
- Post n°41
Re: Decoding my vin
I guess I could also take the interior out and look for the sticker.
Does anyone else have a tach in there gauge cluster? I was told by a person that fixes speedometers thathhe's never seen one in a van
- Post n°42
Re: Decoding my vin
- Post n°43
Re: Decoding my vin
I checked my 1969 Chevy Truck Chassis Service Manual and did not find any indication of a tach in any models for 69.
Joe Van- Moderator 1st Class
- Number of posts : 4619
- Post n°44
Re: Decoding my vin
JMO..It is a "Nice Looking" conversion "NO Doubt" But the factory would have not used a threaded rod for a support brace and the cross-member sure looks like one from a 4x4 pick up truck or suburban... It would have been riveted or bolted on by the factory and not welded in..I owned a 1978 G30 Pathfinder converted van for about 10 years and it had the same 203 transfer case as all the 4x4 Chevy trucks did along with other truck suspension parts at that time.. ... https://imgur.com/AXNCiCe Also most all 4x4 1/2 ton Chevy trucks & suburbans & blazers had 2 leaf springs up front..In my opinion and by the looks of it someone parted out a older 4x4 suburban to build your van.. .."BUT" I could be wrong.!!!..
- Post n°45
Re: Decoding my vin
- Post n°46
Re: Decoding my vin
- Post n°47
Re: Decoding my vin
- Post n°48
Re: Decoding my vin
- Post n°49
Re: Decoding my vin
- Post n°50
Re: Decoding my vin
Thanks for sharing all your knowledge with me.
