    Help decoding
    Help decoding Empty Help decoding
    Post by Guest Tue Apr 16, 2013 11:48 am
    Hello everyone,
    I've returned to the shop where the van is and took many, many pictures. As it turns out, the van does not run. It "cranks frrely byt will not turn over." It has the I-6 motor and I am returning with a mechanic to price a motor re-build. In the mean time, could anyone point me to a good site where I couldtranslate this VIN: GS 163 OX PC 2512 W
    Help decoding P1040110
    Any help would be great!
    Thanks again!
    Post by Joe Van Tue Apr 16, 2013 1:02 pm
    HEY I would like to decode mine vin too. CALLING Donivan Where Are You we need your help!!!! lol! ........JOE VAN........ WELCOME SyFyGuy to VV !!!!!!!!!!!
    Help decoding Empty Re: Help decoding
    Post by donivan65 Tue Apr 16, 2013 1:41 pm
    About the only thing it will tell you is what year the Van is,and if it came with a 6 or 8 cylinder engine,,,,,,a 1/2 ton has 5 lug wheels,,,,a 3/4 ton has 6,,,,,they came in the short, 90 inch wheelbase or the longer 108 inch,,,,,,and panels and 3 flavors of SportVan or its GMC brother,,,,the HandiBus,,,,, if an engine wont run, then you need to run tests on it to check out its condition to determine if it has problems,,,,,might be something minor,,,,,
    Help decoding 2nd_ge14
    THIS IS FOR CHEVY
    G=Van
    S=6 cyl
    1= 1/2 ton 2=3/4ton
    5=panel 6= SportVan
    0= 1970
    GRAYGHOST
    GRAYGHOST
    Number of posts : 47
    Registration date : 2010-10-31
    Help decoding Empty gmc vin decoded
    Post by GRAYGHOST Tue Apr 16, 2013 5:00 pm
    G = van
    S = six cylinder
    1 = 1/2 ton
    63 = 108 wheelbase
    OX = model ?
    P = pontiac plant [ build facility ]
    c = 1967 model year
    2512 = serial number , starts at 1001 that being the first off the assembly line
    W = suburban model custom [ window van ], the OX I cannot get any specific info on, hope this helps Terry
    Post by Guest Thu Apr 18, 2013 2:27 pm
    gr8! thanks forthe help guys. I know the VIN is pretty trivial, but I like to know what is was to see if it was modified at all. thanks again! Also, how many pics can I post using this sites pic uploader. I have a lot of pics of it and would not mind some second opinions.
    thanks!
    Post by G-Man Thu Apr 18, 2013 3:17 pm
    You can post as many as you want, I've posted hundreds over the years
    ditdater
    ditdater
    Number of posts : 590
    Help decoding Empty 1st gen too
    Post by ditdater Thu Apr 18, 2013 6:41 pm
    does that code work for 1st gen g10 also ?
    Post by donivan65 Fri Apr 19, 2013 11:12 pm
    There are all kinds of different VIN Types on our vans,,,,,,for Chevys, 64 is different than 65 and 66 which are different than 67 to 70 and GMC ones don't make sense at all......
      Current date/time is Thu May 02, 2024 10:42 am
