Need Help Decoding G10 Vin
Van Solo
Number of posts : 5
Registration date : 2016-09-25
Post by Van Solo on Sun Sep 25, 2016 12:20 pm
The Vin number I have Starts with G1256P but can't find anything with "56"
Number of posts : 11605
Re: Need Help Decoding G10 Vin
Post by donivan65 on Sun Sep 25, 2016 3:10 pm
that says 1/2 ton 1966 panel
Number of posts : 1412
Post by Vantasia on Mon Sep 26, 2016 10:01 am
Look at this info from VCVC (Vintage Chevy Van Club)
P=Pontiac Assembly, Pontiac MI
4=Scarborough Van Assembly, Toronto ON (1963-1993)
5=London Assembly, London ON
Here's an example 1st Gen VIN, based on a Canadian member's:
4G1205123456GA
4=1964
G=Chevy Van (unitized body)
12= 1/2 ton, forward control, might be 1200 lbs GVW
0=body style?
5=London, ON (P=Pontiac, 4=Scarborough)
123456=factory serial number by year?
GA=Engine/transmission combination, A probably means PowerGlide
Here's an example 2nd Gen VIN, based on mine:
GS158P123456
G=Light duty, forward control
S=L6 Engine (E=V8)
15=load capacity of 1500 lbs
8=1968
P=Pontiac (4=Scarborough, 5=London)
123456=sequential serial number
So as Doni says, you have a 1/2 ton 1966 (P)anel built at the London, Ontario plant, but the P could be Pontiac and the 5 could be body style?
Post by donivan65 on Mon Sep 26, 2016 10:31 am
our Chevy vans use 3 different types of VIN numbers,,,,,the 1964 is different from the 1965 and 1966 and the 1967 to 1970 are different than the other 2,,,,,,,,,
    Current date/time is Wed May 23, 2018 9:28 am
