who can decode that
+4
got2bowl
8 posters
Decoding my vin
got2bowl- Number of posts : 55
Registration date : 2010-12-10
Decoding my vin
GE269P722058
who can decode that
who can decode that
Space Truckin- Number of posts : 1279
Re: Decoding my vin
VIN Format: 1967-1971 Chevrolet truck
Decoding: GE269P722058
1 | Type | G | Chevy Van / Blazer |
2 | Engine | E | V8 |
3 | GVW | 2 | 3/4 ton |
4 | Body | 6 | Suburban |
5 | Year | 9 | 1969 |
6 | Plant | P | Pontiac MI |
7-12 | Sequential Serial # | 722058 | 722058 |
Re: Decoding my vin
Thanks
Do you know what the suburban means?
And is there a way to find out the original options and color?
Re: Decoding my vin
google that!!
- Number of posts : 12218
Re: Decoding my vin
6 might mean SportVan,,,,,,is that what you got?
Re: Decoding my vin
Everything I've seen says suburban. My van is a 4x4 and its a late model 69 so I'm wondering if the suburban means factory 4 wheel drive.
Re: Decoding my vin
but yes it is a sportvan
Re: Decoding my vin
If your van is not paneled, you can try looking at the passenger side inside rear quarter panel and if you are lucky the "birth certificate" (SPID) might still be attached. I do not believe any of our vans came from the factory 4x4, Donivan would be able to answer that though.
Re: Decoding my vin
I doubt that the factory did the conversion,,,,,,is it an automatic transmission,,,,,did someone just drop the body on a 4WD frame and drivetrain,,,,,,,does the transmission hang from the floor or sit on a crossmember,,,,,does it look professionally done or just a hack job
Re: Decoding my vin
its not a hack job by no means it does look really nice if it's not factory
Re: Decoding my vin
Pix????
Re: Decoding my vin
surburban was GM's stand alone vehicle -never a "VAN"! made since the 30's if memory serves me still??
Re: Decoding my vin
I don't know how to post pictures with the transmission isn't mounted to the frame. The he transfer case is mounted to the frame
Re: Decoding my vin
Use imgur, makes it easy for this dinosaur
Re: Decoding my vin
https://imgur.com/y7vn8kB
See if that works
See if that works
Re: Decoding my vin
That is a link, it works though
Re: Decoding my vin
vans don't have frames,,,we need transmission and drive shaft pictures,,,,,do you have a 90 or 108 wheelbase,,,,,,,
Re: Decoding my vin
- Post n°19
Re: Decoding my vin
are those pictures good or do you want better angles ?
- Post n°20
Re: Decoding my vin
108 wheel base
- Post n°21
Re: Decoding my vin
back up a little more on those pictures and lets see how the transmission and transfer case mounts up,,,,,and lets see what the rear ends look like,,,,,,
- Post n°22
Re: Decoding my vin
GMman- Number of posts : 798
Registration date : 2014-10-14
- Post n°23
Re: Decoding my vin
2nd gen Chevy vans did not have factory 4wd. Somebody did a very good conversion. Factory 4wd didn't come until the 3rd gen Chevy Van was produced.
- Post n°24
Re: Decoding my vin
1970 was the first year 4 wheel drive was offered.
This might be a special order van .
I was told that the spot lights were also a stock item for my van.
- Post n°25
Re: Decoding my vin
what kind of springs do you have on the rear ends,,,,,
