    rust fixes
    softesttouch
    softesttouch
    Number of posts : 64
    Registration date : 2010-10-22
    rust fixes Empty rust fixes
    Post by softesttouch Mon Oct 13, 2014 1:55 am
    two obvious areas of advanced rust......this one and, to a lesser degree, near the fuel tank spout.  I KNOW these areas need to be cut out and replaced, but where do I dras the line between major and minor rust fixes?
    rust fixes Bkmobi10
    kookykrispy
    kookykrispy
    Number of posts : 1533
    rust fixes Empty Re: rust fixes
    Post by kookykrispy Mon Oct 13, 2014 7:58 am
    The floor is rusting because the windshield is leaking and allowing water to go down there. Grind the rust scale away with a wire wheel and then if there is enough metal left, just pin holes, you can seal it with the fiberglass-infused body filler (duraglas). Same with the area near the gas filler. The gas filler rusts because of mud getting thrown off the tire and packing up inside there. Remove the filler snout and clean it real well up inside there. After repairing the rust, by either welding or duraglas, make sure to give it a nice coat of heavy paint inside.
    Number of posts : 801
    Post by panelmanrd Mon Oct 13, 2014 10:54 am
    this is the one I have, if u need it let me know 20.00 plus shipping
    rust fixes Img00314
    softesttouch
    softesttouch
    Post by softesttouch Sat Oct 18, 2014 10:07 pm
    SOLD!. just tell me how to get the payment to you and i will let you know where to send it. thanks
      Current date/time is Fri Apr 26, 2024 10:12 pm
