weve covered this before -yet has anyone used the muratic acid before to clean the rust out of a fuel tank?? just curious as Im told by some motorcycle shops that the way they do it.
gas tank rust??
gas tank rust??
Big W- Number of posts : 3282
Re: gas tank rust??
The last time I used muratic acid to clean some mustang parts it worked great. But I would suggest you use it outside, and not in a small shop where their might be any exposed metal surfaces close by...lol...I didn't and everything in my dads garage that was bare metal was covered in a light dusting of oxcidization. Kinda looked like stuff was starting to rust...OOOOps my bad. Just my .02 cents worth on this.
Re: gas tank rust??
well ur correct as many years back now i had the same thing happen Thank you
Re: gas tank rust??
That stuff is nasty and hence effective. After using muratic on mine, I rinsed it real well and then used the Miracle Paint kit that had cleaner, etch (a different acid) and then the coating which takes a long time to solidify. As I am doing this slowly I had weeks to move the tank around to keep the liner flowing. Of course, I won't know how well it all works until it fails. So far so good, happy motoring.
Re: gas tank rust??
i have my radiator guys clean and coat mine, runs me about a hundred bucks.
