    Front end rebuild
    vanman2
    vanman2
    Number of posts : 73
    Registration date : 2012-06-09
    Front end rebuild  Empty Front end rebuild
    Post by vanman2 Sat Dec 21, 2013 5:21 pm
    Hey All First off Merry Christmas & a Happy Healthy New Year To All !!!
    i am looking to rebuild the front end on my 1965 Dodge A-100 van any and all help will be much appreciated not sure what parts are needed   King Pin Set nylon of metal bushings tie rod all i can find is outer right side is there more and where can i find the parts ??~~~~ i will be using Moog i hope !
    thanks in advance vm2 jim
    A100 Wrench
    A100 Wrench
    Number of posts : 572
    Front end rebuild  Empty Re: Front end rebuild
    Post by A100 Wrench Sat Dec 21, 2013 7:16 pm
    Use the metal bushings.Harder to install,but last longer.
    BADBADGER
    BADBADGER
    Number of posts : 246
    Front end rebuild  Empty Front end rebuid.
    Post by BADBADGER Sun Dec 29, 2013 9:09 am
    Seems like I got alot of part numbers and suppliers on the A van forum. I have a list of the parts i used but cant get to it for afew days. If you are still in need then send me a pm and ill dig it out.
    61v100
    61v100
    Number of posts : 29
    Registration date : 2013-11-12
    Post by 61v100 Sun Dec 29, 2013 10:50 am
    Left side tie rod end is ES2887, king pin set is a moog8453B, got mine off rockauto for around $45 delivered. I threw my bushings into the freezer overnight and it went together real easy, make sure you use the right shims or you'll be pushing the pin out again.
      Current date/time is Sat Apr 27, 2024 5:58 am
