Help new finding parts to rebuild 65 chevy front end. Thanks John
Parts available to rebuild first generation chevy front end
AV65chevy- Number of posts : 18
Registration date : 2013-09-15
gfleduc- Number of posts : 367
Frt End Part
What you need info on; Details?
Bushings?
Steering links?
Kingpins?
Bearings?
Bushings?
Steering links?
Kingpins?
Bearings?
Hi Gary all of the above if I’m gonna do it I may as well do it all.after 56 years
I did replace the brakes and bearings
savage likes this post
Someone on this site put together a list of Chevy parts and where to get them. I'll copy and paste for your perusal...These were from 2014 so some prices may have changed but at least it gives you a starting point...If someone has the list of where to get bushings, bearings , etc, they could add to this list so you guys can see them all in one spot...
Rubber parts: Dec 2014
Item Manufacturer/Seller part number price USD$
W/S gasket 1st gen Auto Obsession WBL-653 $40
W/S gasket 2nd gen Auto Obsession WBLD693 $58
Vent window main seal Steel Rubber Prod 70-2115-55 $107 pr
Vent window Division post Steel Rubber Prod 70-2116-56 $58 pr
Front door seals Steel Rubber Prod 70-2584-72 $95 pr
Cargo door seal Steel Rubber Prod 70-2585-72 $128 one set
Dog house seal Steel Rubber Prod 70-3531-88 $16
Vent window setting channel Steel Rubber Prod 70-2170-57 $3 /ft
Hinge gaskets Steel Rubber Prod 60-0659-69 $35 (4) one door
Hinge gaskets Clarks C9946 $ 8 ea
Door bumpers Steel Rubber Prod 33-0496-71 $2 (2/door)
Window bottom bumpers Steel Rubber Prod 33-0531-42 $3 (1/door)
Glove box door bumper Steel Rubber Prod 33-0128-88 $1 (need 2)
Glove box door bumper Clarks C853R $6 pr
Window fuzzy kit Steel Rubber Prod 80-0788-59 $105 2 door set
Brake/clutch pedal Steel Rubber Prod 70-3531-88 $23 pr
Swing out window seal Restoration specialties VSG001 $1.50 / ft
Door button O ring Clarks C565 $.70 ea
Door lock gasket Clarks C566 $2 ea
Door handle (small) Clarks C1550 $1.40 ea
Door handle (large) Clarks C1549 $1.55 ea
Door handle escuteon gasket Clarks C6530 $1.50 ea
Door handle black button Clarks C5851 $9.00 ea
Door black button screw Clarks C5852 $0.90 pr
Division bar rivets Clarks C7664 $5 set
License plate bumper Clarks C532 $3 ea
Vent window pivot rivet Clarks C2701 $3.35 ea
Ash tray bumper Clarks C2563A $2 ea
The following three items in Canada at 25% or less of the USA price. (And they sell to the US). are in Canadian dollars, at this time subtract about 17% to get the USD price.
https://www.hitechglazing.com/catalog/40001
Fixed window rubber HighTech Glazing AS-1216 $60 (50 ‘roll)
Locking strip HighTech Glazing AS-789 $16 (50’roll)
Division bar SS bead. HighTech Glazing Y658X96 $35 (96")
Sometimes the division bar can be cut in two 48” pieces to reduce shipping costs.
Less then 4’ needed for each window.
From Smiley’s list
Bat box lid gasket Dan’s Classic CD43-311 $4.20 ea
Brake pedal rubber American Classic FL108 $2.50 ea
Glove box lock gasket Classic Parts 22-412 $0.75 ea
Door bumpers (4) Classic Parts 18-321 $.99 ea
Window bumpers (2) Classic Parts 18-360 $.75 ea
Note: Steel Rubber Products are made in the USA. The items from HighTechGlazing are either made in USA or Made in Canada.
Other similar items found cheaper are off shore (usually made in China). I have found the off shoe items don’t fit as well as the made in North America ones.
M1D
Door bumpers to stop door rattles:
http://www.corvair.com/user-cgi/catalog.cgi?function=goto&catalog=MAIN§ion=MAIN&page=230
From Smiley’s list
M1D
I just used the Seach tab at the top of the page and searched on bushings and found and old thread that Donivan had some nice pictures with item numbers, etc...that might help you out...
https://vintage-vans.forumotion.com/t56151-leaf-springs-and-bushings?highlight=bushing
Thanks for all The quick response makes things so much easier. Ordered up all the parts today thanks to everyone for your help
In a couple of days, this post will be moved over to the G Parts Wanted section so everyone can see these part numbers,,,,,,,
