    FRONT OF DRIVE SHAFT BOOT/ FRONT FLOOR MAT A108/318 auto
    FRONT  OF DRIVE SHAFT BOOT/ FRONT FLOOR MAT A108/318 auto Empty FRONT OF DRIVE SHAFT BOOT/ FRONT FLOOR MAT A108/318 auto
    Post by Guest Tue May 19, 2009 7:15 am
    cruising has begun!!! it's A108 time!!
    checking to see what you lads do for a replacement boot for the front drives shaft u-joint. Presently a tie wrapped tire tube cut piece is worn right out and I would like to get something alittle more original or at least proffesional!!.
    Also looking for a custom front floor mat, sick of the handy dandy home cut one, any scources out there, so far all dead ends!!
    affraid
    FRONT  OF DRIVE SHAFT BOOT/ FRONT FLOOR MAT A108/318 auto Empty Re: FRONT OF DRIVE SHAFT BOOT/ FRONT FLOOR MAT A108/318 auto
    Post by Guest Thu May 21, 2009 9:10 am
    JC Whitney used to sell a repro. rubber floor mat, bu not any more. NOS or good used is probably your only option.
    You may be able to use a CV "Speedi-Boot" on that ball and trunnion joint. Take some measurements and you may be able to match something up. Or swap over a front u-joint set up.
    Post by Guest Thu May 21, 2009 2:52 pm
    I used a modern CV joint boot with some plastic tie straps. Not sure which boot, but I recall it was a little too long I had to cut it down. But now I'm converting to a modern slip joint thing.....
      Current date/time is Thu Apr 18, 2024 10:48 pm
