    Brake light switch
    pilotmtnraider
    pilotmtnraider
    Number of posts : 65
    Registration date : 2008-05-30
    Brake light switch Empty Brake light switch
    Post by pilotmtnraider Sun Sep 01, 2013 6:42 am
    Any help would be greatly appreciated. I bought my 65Econo and everything was taken apart for the start of the body work. I have found that the brake light switch is not in place. If anyone has any pictures or can explain where it goes and how it works would make my life a lot more simple. Again, thanks for any help.
    Old Skool
    Number of posts : 1306
    Brake light switch Empty Re: Brake light switch
    Post by Old Skool Sun Sep 01, 2013 2:49 pm
    Your brake light switch works by pressure and is located in a special fitting that goes on the outlet of your master cylinder. The manifold distributes also to the front and the back and also the pressure type brake light switch. I know I have a picture of it some wheres,,, just cant find it,,,will look later if I can. Gotta run,,
    vic
    pilotmtnraider
    pilotmtnraider
    Post by pilotmtnraider Sun Sep 01, 2013 3:05 pm
    Thanks Vic, you are the MAN!
    Post by Big W Sun Sep 01, 2013 11:03 pm
    see the 2 red wires...that's the switch at the end of the master. Attached to the "T" fitting that your brake lines are hooked to.Brake light switch Brake_10
    pilotmtnraider
    pilotmtnraider
    Post by pilotmtnraider Mon Sep 02, 2013 4:38 am
    Thanks Vic. I got it put back together.
      Current date/time is Sun May 12, 2024 4:18 pm
