+4
63chevyvan?
dRomer48
sandyvan
Skulptorchaz
8 posters
    I need a brake light switch.
    Skulptorchaz
    Skulptorchaz
    Number of posts : 326
    I need a brake light switch. Empty I need a brake light switch.
    Post by Skulptorchaz Fri Sep 21, 2018 8:20 am
    Where do you guys find these for a '64?
    I ordered one but they are back ordered and it could be awhile.
    I'd hate to have to fab in a later model switch but, I'm wondering if that might not be the best bet if these are hard to find.
    Thanks,
    Chaz
    sandyvan
    sandyvan
    Number of posts : 526
    I need a brake light switch. Empty Re: I need a brake light switch.
    Post by sandyvan Fri Sep 21, 2018 2:01 pm
    You can get them on eBay
    vintageoldtimegarage on eBay is where I got the last one I bought for my 69, but I put a replacement on my 66 a few years ago too. Simple and easy.
    dRomer48 likes this post
    Skulptorchaz
    Skulptorchaz
    Post by Skulptorchaz Fri Sep 21, 2018 3:53 pm
    Tried it but nothing came up. Question
    Thanks for the help tho.
    gfleduc
    gfleduc
    Number of posts : 367
    I need a brake light switch. Empty Brake Switch
    Post by gfleduc Fri Sep 21, 2018 6:23 pm
    dRomer48
    dRomer48
    Number of posts : 27
    Registration date : 2018-10-01
    Post by dRomer48 Sun Oct 07, 2018 7:52 pm
    sandyvan wrote:You can get them on eBay
    A buddy of mine is looking for those parts, too. Took a quick search and didn't find it either. We'll just finish the installation of the new rack and access tonneau cover on the current truck project and I'll take some time searching for the parts at Ebay. Would appreciate any link.
    gfleduc
    gfleduc
    I need a brake light switch. Empty Brake light switch
    Post by gfleduc Sun Oct 07, 2018 7:58 pm
    Skulptorchaz
    Skulptorchaz
    Post by Skulptorchaz Mon Oct 08, 2018 6:34 am
    Thanks buddy. I went ahead and got that one. The one I ordered from Standard Motor Products is still back ordered, so I cancelled it.
    Thanks again for the heads up!!!
    63chevyvan?
    Number of posts : 125
    Post by 63chevyvan? Thu Oct 11, 2018 11:55 am
    I bought mine at NAPA; there are (3) different mounting configurations for the same switch, hence (3)different part numbers. The part number with the correct mounting config we need has been discontinued, so buy one of the other two and fab an adapter bracket. That's what I had to do.
    Cheers & Gears, MS
    Skulptorchaz
    Skulptorchaz
    Post by Skulptorchaz Sun Oct 14, 2018 2:19 pm
    Thanks buddy. Got it!!
    63chevyvan?
    Post by 63chevyvan? Fri Nov 02, 2018 5:05 pm
    Hello all, upon further research and review I found that Clark's Corvair Parts has the brake light switch for our vans. Their part # C1616, for a Corvair Van, which is a direct fit;$45 pricey but just bolt it on. I got mine today.
    Cheers & Gears, MS
    AzDon
    AzDon
    Number of posts : 742
    Post by AzDon Mon Sep 20, 2021 8:10 pm
    It appears that the Corvair parts place still has this switch listed as of today.... I bought one of the variations that's made for a 57 Suburban..... Got it From RockAuto for just under $15 plus shipping and made an adapter mounting plate to position it exactly like the original (pictures soon).... My old switch was shot internally, but was useful as a pattern...... I wanted the switch on at 1/4" of pedal travel, so I had to "adjust" my new plate by bending it upwards a bit...
    savage and gmytych like this post
    Number of posts : 2626
    Post by savage Tue Sep 21, 2021 7:11 am
    Don, was the arm as long as the stock one???
    I got one for early pickup, and it was too short. Thanks
    Number of posts : 7900
    Post by DanTheVanMan Tue Sep 21, 2021 9:05 am
    I need a brake light switch. Qr_cod10
    gmytych likes this post
    Post by DanTheVanMan Tue Sep 21, 2021 9:10 am
    This one works as well, however you will need to modify or make a mounting bracket for correct placement.
    I need a brake light switch. 375x3712
    https://www.stockwiseauto.com/acdelco-d860a-brake-light-switch?Year=1966&Make=Chevrolet&Model=G10%20Van
    gfleduc
    gfleduc
    Post by gfleduc Tue Sep 21, 2021 3:38 pm
    I have a list of at least 10 P/N's new & old vendors.
    PM me I would be glad to send the list.
    AzDon
    AzDon
    Post by AzDon Fri Oct 01, 2021 8:34 pm
    savage wrote:Don, was the arm as long as the stock one???
    I think the arms are the same length..... The bracket on the original where the bolts attach are behind the switch, holding it out farther.... Also, the shorter bracket is faced the other way....If you have the original, it's easy to measure the differences and make an adapter plate... If you look at the two in the last two posts, you'll see the differences...
    savage likes this post
    AzDon
    AzDon
    Post by AzDon Fri Oct 01, 2021 9:03 pm
    DanTheVanMan wrote:This one works as well, however you will need to modify or make a mounting bracket for correct placement.
    This is the correct switch for a 69 van..... the one in the previous post is the replacement I made an adapter for... I see the AC Delco number is D860A...
    Post by DanTheVanMan Sat Oct 02, 2021 9:58 am
    Here's the little adaptor plate I made about 6 years ago to get the correct placement for the one I used...
    No issues at all since installed...
    I need a brake light switch. 20211011
    I need a brake light switch. 20211010
    AzDon
    AzDon
    Post by AzDon Sun Oct 03, 2021 5:33 pm
    Mine looks very similar...
    I need a brake light switch. Brake_10
    I need a brake light switch. Brake_11
    I need a brake light switch. Brake_12
    I need a brake light switch. Brake_14
    I need a brake light switch. Brake_15
    I need a brake light switch. Brake_13
    savage, gmytych and DanTheVanMan like this post
    dRomer48
    dRomer48
    Post by dRomer48 Thu Nov 11, 2021 3:10 pm
    My uncle got this 69 project it needs a few brake parts. The previous owner's son messed with it. We're gonna take a closer look after we finished installing the brake kit and nitto ridge grappler tires on the truck and clear the garage. We'll check vintageoldtimegarage soon.
    gfleduc
    gfleduc
    Post by gfleduc Fri Nov 12, 2021 3:01 am
    PM me your email address I have a list of P/Ns you can check on.
      Current date/time is Tue May 07, 2024 2:34 am
