    brake lights on
    chainsaw
    chainsaw
    Number of posts : 226
    brake lights on Empty brake lights on
    Post by chainsaw Thu Sep 26, 2013 12:45 pm
    Drove to the store and when I got back noticed the brake lights were still on. When you push on the brake pedal and let off, the brake lights go off for a second then slowly come back on. All other lights work fine. Would a bad brake switch keep the brake lights on? Where do I start looking, by the way, its a 62. Thanks.
    scarlin
    scarlin
    Number of posts : 258
    brake lights on Empty Re: brake lights on
    Post by scarlin Thu Sep 26, 2013 1:22 pm
    The Brake lights work off a switch on the back of the master cylinder (61-66). If the seal goes bad it will fill up with brake fluid and provide a path for current to flow to the lights. Can't help with a PN.
    Carl
    Number of posts : 143
    brake lights on Empty Brake light switch
    Post by Carl Thu Sep 26, 2013 3:27 pm
    Mac's Antique Auto Parts has it; part# C1AZ-13480-A Phone# 1-800-777-0948, or online www.macsautoparts.com Stop light switch $7.95
    chainsaw
    chainsaw
    Post by chainsaw Thu Sep 26, 2013 4:33 pm
    Thanks guys, I'll order one tomorrow. I sure hope its that simple, I can figure out most things except for electrical problems. `Luckily , the truck had been completely rewired when I got it and everything has been working fine till now.
    Number of posts : 655
    Post by 61econoline Thu Sep 26, 2013 10:18 pm
    napa should have the brake light switch
    chainsaw
    chainsaw
    Post by chainsaw Fri Sep 27, 2013 6:10 pm
    Went and got my new switch, hooked up the battery to move the truck to replace it and the brake lights turn off now. Now I'm wondering if its really the switch or a short.
    chainsaw
    chainsaw
    Post by chainsaw Sun Oct 06, 2013 5:54 pm
    Changed the brake switch and the lights turn off now. Never knew the brake switch could keep the lights off as well as on. Thanks again guys.
      Current date/time is Tue May 07, 2024 4:56 am
