by RodStRace Sat Dec 28, 2013 7:47 am
B, one tie rod end is regular right hand thread, the other is left hand thread and is hard to find. The reason for the different threads is so the clamps can be loosened and then the tie rod turned to adjust the length, setting toe. If they were both right hand thread, you would have to remove one to adjust, and be limited to only a full turn to adjust.
I'd start with the usual parts stores and try to get a number to cross-reference.
The Right hand one is Raybestos 401-1022. The other is probably Raybestos 401-1021. 23 is a Chevy application.
MOOG is ES140R, the other would seem to be a ES140L, but that one is way different (Jeep).
Find out any other brand and numbers and do searches. Also find the OE part number and look for it too.
If all that fails, try the specialty parts places. There is
www.arizonaparts.com www.kanter.com does not show one.
robwerts motor parts doesn't either.
I did find this thread when searching
http://forums.aaca.org/f120/dodge-a100-parts-interchange-question-288759.htmlIt mentions Rare Parts. Give them a try. Also, when you do find a source, share it with others here!
