    Carter carb
    hometeam
    hometeam
    Number of posts : 101
    Registration date : 2013-01-21
    Carter carb Empty Carter carb
    Post by hometeam Fri Jun 07, 2013 8:49 pm
    I have a carter ball and ball carb with the part # 2072 stamped on it
    I have a 67 a108 with a slant 6 3.7 225 automatic trams.
    I am always having to unstick or reconnect components - if it isn't vacum diaphragm getting hung up or float sticking causing it to flood and stink up cab with gas. Wasn't that noticeable until I cleared up vapor lock issues witch revealed carb issues. After tweaking and starting and more tweaking i get it starting nice idling nice drive it on a few short trips here and there and the problems start up again- blackish splatter out of exhaust that goes away after warm - needs a few pumps to start-rugh cold idle which will lead to the two foot driving from neutral to drive. And the readjustments begin.
    Looked up carb and this part # and from what I get it comes out of a 53 Cadillac is this correct? i want to have it rebuilt but is it wise to do so if the carb is the wrong one for the car.
    Do I just start from scratch with a whole new set up.
    Or stay with the devil I know ?
    hometeam
    hometeam
    Carter carb Empty Re: Carter carb
    Post by hometeam Fri Jun 07, 2013 9:48 pm
    After more research I may have a carter ball and ball that came with a metal tag I'd
    Either a carter BBS or BBR anyone know the difference?
    Number of posts : 956
    Post by slowflapper Mon Jun 10, 2013 12:15 pm
    BBR/BBS are different types of single bbl's.
    link
    hometeam
    hometeam
    Post by hometeam Tue Jun 18, 2013 7:04 pm
    carbsonly in burbank is fantastic . fair pice and knowledgeable.
    work done quick. i am up and running better than ever.
    mikes carburetor also has parts.
    for anyone trying to identify a carter carb w/out part # tag.
    send carbsonly a picture and carlos can assist you in identifying it.
    my 67 a108 carter carb - was a carter ball and ball "S" with a u shaped throttle linkage.
    with manifold choke thermostat.
      Current date/time is Thu May 02, 2024 6:13 am
