I was wondering if anyone has a source or field engineered a solution for missing 3 on the tree shift rod grommets (bushings). These are the ones that mount in the bracket that also has the parking brake pulley that is located between the front drivers side tire and the engine. I recently upgraded to a dual master cylinder and the missing grommets cause one of the rods to sag so much that it rubs the top of the master cylinder. I read somewhere that the parts #'s are 3854838 & 3971312, but those numbers seem to be discontinued with no superseding #.
Any advice is appreciated.
