Seth G wrote:I've been debating wether to buy a shifter or try and go with Vic's column shift conversion, was planning on the lokar tv cable. If you can I'd like to know what the Lokar part#'s you used were, esp the tv cable, there are a couple of options if iirc.
Ill try to dig up the part number, but I can tell you that it is the floor mount shifter made for the AOD, with an extended cable that I think was 96 inches. I used the factory TV kickdown cable because is hooked to the throttle linkage. I know there is some adjustment needed when you use the TV cable when you use the column shift kit, but I have heard once you get thru that it works great.
