+12
64chevy
16 posters
    The Blue No Door
    The Blue No Door - Page 3 Empty Re: The Blue No Door
    Post by donivan65 Mon Aug 25, 2008 5:23 pm
    Next project is to take off the front springs. The front end is 3 inches higher than the rear because there is an extra leaf in there,,,,it now has 7. And I could cut him a tree tire while I am at it.
    The Blue No Door - Page 3 Nodoor12
    The Blue No Door - Page 3 Nodoor13
    The Blue No Door - Page 3 Nodoor14
    Post by donivan65 Tue Aug 26, 2008 7:38 pm
    Looks like someone used a torch to cut off the old springs, so I had to build up the area around the bolt today.
    The Blue No Door - Page 3 Nodoor15
    The Blue No Door - Page 3 Nodoor16
    The Blue No Door - Page 3 Nodoor17
    Number of posts : 1046
    Post by VANagain Tue Aug 26, 2008 11:45 pm
    Geez, Vanish, after reading through this long thread, I hate to say it but this no-door was a real lemon!
    Very Happy
    Post by Vanish Wed Aug 27, 2008 7:25 am
    Yep... I not sure if it's a Lemon..... or just Plain 40 years of worn out !!!!!!!!! The Good news is it's starting to take shape now ...... Thanks to Don......
    Post by donivan65 Wed Aug 27, 2008 9:30 am
    And he will have one nice glass of Lemonade when it's done!
    Post by donivan65 Wed Aug 27, 2008 2:15 pm
    And today I pulled off the front suspension,,,,,,,
    The Blue No Door - Page 3 Nodoor18
    The Blue No Door - Page 3 Nodoor19
    The Blue No Door - Page 3 Nodoor20
    The Blue No Door - Page 3 Nodoor21
    Post by VANagain Wed Aug 27, 2008 10:25 pm
    That's a joke at my house. My mom has never seen my house but hears about all the work I'm doing on it, so she says in a hushed voice, "I think you got a lemon..."
    Like Don told me, no matter what van we pick up, we gotta go through everything. And by now these vans usually need everything!
    Don, you're making it look easy, rolling that new front end under there!
    Post by donivan65 Wed Aug 27, 2008 11:14 pm
    I guess you are more qualified to to talk about Lemons than the rest of us,,,,,,,,,,,,
    Number of posts : 2626
    Post by savage Thu Aug 28, 2008 4:19 am
    Don, You have any problem getting everthing lined up ,to bolt back together???
    Post by donivan65 Thu Aug 28, 2008 9:42 am
    It went back together in minutes, I had the new front suspension all apart. I just lifted a spring up and slid the front bolt in, lifted the rear and slid the shackle in, raised the axle up with a floor jack so that the centering bolts lined up into the bottom of the springs and dropped the U bolts right down and tightened it all up.
    Post by donivan65 Mon Sep 29, 2008 5:52 pm
    Now back to the sway bar,,,,,,Since I put that dual line master cylinder in, you need to make up some spacers to lower the sway bar mounts so it runs under it. If you don't have the threaded inserts in the frame, you need to heat up some 3/8" threaded rod into a U- bolt and hook it up into the frame and hang down so you can bolt on some 2" square tubing for a spacer.
    The Blue No Door - Page 3 Repair20
    The Blue No Door - Page 3 Repair21
    The Blue No Door - Page 3 Repair22
    The Blue No Door - Page 3 Nodoor10
    The Blue No Door - Page 3 Nodoor11
    Post by VANagain Tue Sep 30, 2008 9:19 am
    That is so clever how you "hooked" the threaded rod through the frame. At first I didn't get it, looking at the photos, but then I understood that you can feed the u-bolt in one hole and get it to come out the other. And then you've in effect got two studs coming out!
    Of course us Sportvan owners don't need to bother! Cool
    Post by donivan65 Thu Nov 06, 2008 10:38 am
    I got 3 new exhaust systems made up for me, Vanish and VanAgain,,,,,,but someone don't want to share,,,,,,
    The Blue No Door - Page 3 Exhaus10
    The Blue No Door - Page 3 No_exh10
    64chevy
    64chevy
    Number of posts : 364
    Post by 64chevy Thu Nov 06, 2008 1:50 pm
    No mufflers...??? Is that the latest performance mod for these earlies?
    Post by donivan65 Thu Nov 06, 2008 2:59 pm
    Oh,,,,,,,It sounded like you were already running your van that way at Econowest,,,,,,,,,
    The Blue No Door - Page 3 Econow10
    64chevy
    64chevy
    Post by 64chevy Thu Nov 06, 2008 5:54 pm
    Yea..I was. But it was a short pipe and a little noisy inside. And I was leary of a ticket. Maybe I should have passed on spending $75 for a muffler and instead just added some length to the exhaust. At least that would have gotten the sound out the back where the CHP wouldn't have any problem hearing it.
    The Blue No Door - Page 3 Empty Exhaust pipes looking good!
    Post by VANagain Fri Nov 07, 2008 1:15 am
    Those exhaust pipes look great!! Who's not going to share? I'll set aside some cash for you for next time you visit!
    Post by donivan65 Fri Nov 07, 2008 8:17 am
    The Blue No Door told me he wants all 3 exhaust systems put on him so he can have headers,,,,,,,but that ain't going to happen,,,,,,all 3 vans get the same exhaust system,,,,,
    Post by donivan65 Fri Aug 07, 2009 9:37 pm
    So,,,,,,,Vanish brings me a radiator, trans cooler, a 4 way hazard switch, and another years registration,,,,,,,,,,,,I think this is the Blue No Door,,,,,,,,The starter sometimes won't crank so I slap one of those Ford relays on it and cranks great now,,,,,
    The Blue No Door - Page 3 Nodoor22
    Post by G-Man Sat Aug 08, 2009 4:26 am
    Don, whats left to do to the No Door??? Also get us a picture where you mount that trans cooler
    Post by donivan65 Sun Aug 09, 2009 11:06 am
    Ok,,,,slapped the radiator in,,,,new heater hoses,,,,and that cooler,,,,24",,,,,I guess it would be most efficient if I mounted it on the bumper,,,,but somebody would probably complain,,,,I think under the floor, in front of the stop light switch, will be its home,,,,,and I need to modify this 2nd Gen bellypan,,,,since now a Swaybar is all of the sudden in the way,,,,,,
    The Blue No Door - Page 3 Nodoor23
    The Blue No Door - Page 3 Nodoor24
    The Blue No Door - Page 3 Nodoor25
    Number of posts : 1388
    Post by wideload Sun Aug 09, 2009 12:17 pm
    Don does the knob and stem come out of the four-way flasher like it does in a headlight switch ? Would the stem from a headlight switch work for a replacement? The switch is on my 65 but there's no knob or stem.
    Post by donivan65 Sun Aug 09, 2009 6:59 pm
    So where is yours mounted,,,,does it look factory? I seen these mounted next to the fuse box on some SportVans WAY OUT OF THE WAY,,,,and this one has 2 male and 1 female connector on it as to be put into series with the turn signal switch connector. But 1st Gens only have 1 connector, so maybe this is for a 2nd Gen,,,,,and the thing that would of got rid of this would of been if you got the button on the opposite side of the turn signal to press for 4 ways,,,,,,do you have that button on any of the 2nd gens? So I might have to work hard to get these lights to flash,,,,,,and the knob only comes out 1/4", it unscrews and has a bulb in there,,,,,
    The Blue No Door - Page 3 Nodoor27
    Post by savage Sun Aug 09, 2009 8:35 pm
    Don those end look just like the ones on my 64 & 65's. I got the 2 plugs coming from TS and the 1 from vans harness. My guess is you plug the 2 off flaser in to the 1 on vans harness and the 1 on flasser into the 2 on TS?? How about mouting it on the other side of where the heater switch is??
    Post by Vanish Sun Aug 09, 2009 9:15 pm
    Man Some One always has Plans for that front Bumper !!!!!! Man we should Tak it Off !!!!!!!!!
    The Blue No Door - Page 3 Mmm
    Before !!!!!!!
    Now !!!!!!.......................................... But I must say I Like Dons version Better !!!!!!!!!!!!!!!!!!!
      Current date/time is Thu May 16, 2024 9:52 pm
