+12
64chevy
16 posters
    The Blue No Door
    Number of posts : 7900
    The Blue No Door - Page 5 Empty Re: The Blue No Door
    Post by DanTheVanMan Fri Aug 21, 2009 5:33 am
    Bill,
    That is sooooo scary!!! affraid
    The Blue No Door - Page 5 Qr_cod10
    Number of posts : 1388
    Post by wideload Fri Aug 21, 2009 5:37 am
    I better take mine off and lock it up somewhere !!!!!!!!
    Post by G-Man Fri Aug 21, 2009 8:08 am
    For that money I could live without one
    Post by donivan65 Fri Aug 21, 2009 9:00 am
    That one is for an Impala,,,,,,but the 64-66 Chevy Malibu, Chevy ll , El Camino, Pick ups, Corvette and Corvair, used the same turn signal switch on the Chevy Vans which have the same connectors on it.
    Number of posts : 1651
    Post by Scott Fri Aug 21, 2009 10:08 am
    I better get my Credit Card out before somebody else snatches that baby..
    Bet I can get those missing directions for as little as $300.
    Post by donivan65 Sat Oct 03, 2009 11:59 pm
    And look,,,,,,another bunch of parts show up,,,,,,Volt, Oil and Temp gauges with senders,,,,,turn signal switch,,,,,,,rear cargo lights,,,,,
    The Blue No Door - Page 5 Cruisi47
    The Blue No Door - Page 5 Nodoor52
    The Blue No Door - Page 5 Nodoor53
    The Blue No Door - Page 5 Nodoor54
    Number of posts : 917
    Post by wylee Sun Oct 04, 2009 4:15 am
    nice. im doing the same with gauges, what a pain trying to hook them up.
    Post by G-Man Sun Oct 04, 2009 5:24 am
    Now those are back-up lights!!!!
    Post by donivan65 Sun Oct 04, 2009 10:32 am
    That wiring can be harder than it needs to be if you don't have a plan for it. I ran 2 wires down by the gas pedal and back to the temp and oil senders. I ran 6 wires to ground under the dash for the 3 gauges and 3 back lights. I ran the 3 hot wires with an inline fuse to the Ignition Unfused terminal on the fuse box,,,,,,I ran the backlight wire to the terminal on the Panel light fuse. That whole fuse comes from the dimmer section on the headlight fuse. I ran a wire up through the channel above the drivers window all the way back and down past the left rear tail light through the fuel sender grommet to the rear lights. And I found why there was a piece of copper tubing instead of a tail light fuse,,,,,,the right rear tail light wire that goes inside the channel over the rear doors was burnt from being pinched by a metal clip that holds it into place,,,,,,now that is something that we need to check on,,,,,,,
    Post by donivan65 Thu Oct 08, 2009 3:45 pm
    So Vanish says he likes uncluttered dashes,,,,,,,WELL,,,,,,,,,I got a new blade in my air saw and a hunk of metal on an old metal filing cabinet,,,,,so lets see if we can do a little clean up on the Blue No Door.......
    The Blue No Door - Page 5 Th_NoDash
    Post by wideload Thu Oct 08, 2009 6:23 pm
    Looks good Don !!!!!!!! Now where is the radio going to go? Got to have tunes when cruising.
    Post by Vanish Thu Oct 08, 2009 9:38 pm
    Thanks Don The Dash Looks Good ........ I Love it ......... Mike yep we gotta figure out were the Radio Go's But that Cleans up the dash so Much I just cant believe how Good That Looks ......... one Day it will have a console of some kind But the dash just looks so simple and Clean That way ....
    Post by donivan65 Thu Oct 08, 2009 11:11 pm
    The Blue No Door - Page 5 Nodoor57
    Post by wylee Fri Oct 09, 2009 3:47 am
    nice. what a diff.
    Post by Vanish Fri Oct 09, 2009 6:30 am
    The Blue No Door - Page 5 Nodoor58
    Just want to Thank Don again ..... Looks Great..... This was a combo of Ideas from the show me your Dash Topick..... Thanks to XJAMESX AND gregw98 .... AND OF COURSE DONIVAN65 FOR PUTTING IT ALL TOGEATHER ...................
    Number of posts : 2626
    Post by savage Fri Oct 09, 2009 6:46 am
    Nice job Don, does look a lot better(moe better Laughing )
    Number of posts : 1731
    Post by Admin Fri Oct 09, 2009 9:02 am
    Where ARE you gonna put the radio? scratch
    Post by donivan65 Sun Oct 11, 2009 11:39 pm
    .....more important is where are you going to put the cup holders??????
    Post by donivan65 Mon Nov 16, 2009 12:27 pm
    ,,,,,now we are getting somewhere,,,,,,
    The Blue No Door - Page 5 Nodoor66
    The Blue No Door - Page 5 Nodoor67
    Post by G-Man Mon Nov 16, 2009 12:35 pm
    sweet rims!!!!!
    Post by wideload Mon Nov 16, 2009 3:02 pm
    Don you need to dig out a little more of your yard to make room for a garage for the Blue No-Door. Smile
    Post by donivan65 Mon Nov 16, 2009 4:00 pm
    ,,,,,,,then I would have to add on another bedroom,,,,,
    Post by Vanish Mon Nov 16, 2009 9:51 pm
    Man ..... Wheels and tires Do a lot of Talking Don't They ?????? What are those of of ????
    Post by donivan65 Mon Nov 16, 2009 10:25 pm
    I got us a good deal on 2 complete sets,,,,,,,,,
    The Blue No Door - Page 5 Nodoor68
    Post by donivan65 Mon Nov 16, 2009 10:32 pm
    ,,,,,,actually,,,,,they came on a 61 Corvair Van that we just switched out the engine on,,,,,,,they rub the wheelwells, so I put the No Doors tires on it so he can take it to DMV and get it registered,,,,,,I got a couple of VanAgains old rims that need tires
    The Blue No Door - Page 5 Repair90
    The Blue No Door - Page 5 Repair91
      Current date/time is Thu May 16, 2024 7:31 pm
