OK all you Knowledgeable Guru's- How is the van side door= outside handle =romoved?? Yes i even have the small screw inside the middle of the handle off- cant get it off the door mechanism-help=???
Door handle removal=side door-1967 sportvan
on the inside of the door there is a clip looks like kind of
like a "c" remove it and the handle come out from the
outside. "c" is the same as the ones that hold on the
window cranks and door opener levers.
Thank You very much- is so hard for me to see inside the door - hehe - learned again - foto inside it - smart bunch here Thanx
Found tyhe clip Thanx 2 all
,,,,,,,,,,and the rest of that story,,,,,,
https://vintage-vans.forumotion.com/vintage-vans-general-discussion-f1/behind-door-1-t16450.htm
Scott- Number of posts : 1651
I think they sell those rod clips at Lowes.
I will try to get by Lowes tomorrow to check it out..
