+12
64chevy
16 posters
    The Blue No Door
    Number of posts : 1046
    The Blue No Door - Page 2 Empty Re: The Blue No Door
    Post by VANagain Tue Jul 01, 2008 9:52 am
    The electric fan from the Camaro was too big. I liked it because it had a shroud. The other one that I thought was so small turns out to be a pretty good fit. And it is quieter than the big one and I'd say it moves more air too. I didn't take note of what it came out of but it was a pretty new GM with two of these fans side by side. No shroud. Here's a photo of how it fits:
    The Blue No Door - Page 2 Dscn0411
    I test fit it in my blue van and it ended up perfectly aligned in front of the radiator, about 1/2" away from it. This photo shows it in my other van so you can see how it mounts. The two upper bolts will be easy, into the doghouse, but I need to fashion a couple of clever mounts to go onto the sway bar. Each needs to to provide a slot for a plastic tab to go into.
    My only concern is, will the fan block incoming air when it the fan is off. It's got that wide "ring" around it. And it's a pretty tight space between the radiator and the front of the doghouse, as we all know. But if I hook it up to a thermostatically controlled circuit, it will come on when it gets hot, so it should help more than it hurts. Plus I want to add a switch on a timer that will cause the fan to run for a while after I park, to blow out those nasty fumes that collect after a long drive. That's an idea I got from Donivan65. Works like a charm!
    Number of posts : 236
    Post by Kakster Tue Jul 01, 2008 8:38 pm
    My van, when I got it, didn't have the bottom pan that I think helps direct air up to the radiator. From what I understand it is common that these pans were taken off and not put back since they were a hinderance to oil changes etc. I am wondering do you guys still have a pan on your beasts?
    Do you think they help or hurt or don't matter in terms of cooling and will the added electric fans compenstate for not having one if the pans do help keep the motor cool?
    Post by donivan65 Tue Jul 01, 2008 9:01 pm
    They changed the cooling systems on the 2nd Gens. On the 1st Gens, the radiator goes nowhere,,,the only air that it got was from the bellypan shooting it up from the ground,,,,while you were moving. But then. on the 2nd Gens, the Doghouse got bigger and they built a tunnel in the floor so the air from the grille actually hit the radiator. and they put crossflow radiators that mounted on their sides with a surge tank that got more air flow. But I would say,,,,a bellypan adds more cooling air to the radiator when going down the road.
    Number of posts : 2626
    Post by savage Thu Jul 03, 2008 6:42 am
    So Don I know you posted this before, but what kind & where did you mount the "extra" fan you put on your van for cool down after driving it. Does it come on if it starts to over heat???
    Post by donivan65 Thu Jul 03, 2008 10:19 am
    Hey Tom, We keep getting new members so we need to keep reposting the old stuff that we covered before.
    I don't like the idea of putting a fan right in front of the radiator on a 1st Gen. the air has to come UP from the Bellypan so that might be restricting the airflow. But it might work if you wired the fan with a sending unit to come on automatically.
    But my set up is to just mount a Honda fan on the sway bar and floor with a wind up timer and a switch under the dash. If I am going up a mountain or stuck in traffic or just want to cool down the engine, I turn it on. And I can just crank on 15 minutes on the timer and leave the van to cool off by itself and shut off. I drove the van in 109 degree weather last week and it did not overheat. I sure did,,,,But the vans need to be moving for the bellypan to force that air up through the radiator. Its a small fan, I might try a larger one there.
    The Blue No Door - Page 2 Vanfan10
    Post by Kakster Thu Jul 03, 2008 1:52 pm
    Don, Your fan also gets rid of the gas fumes too after turning the engin off too? That smell of gas is a major turn off for my wife so I will need to do something about it to get her back in my beast once the upgrades are done and it is back on the road. I am tempted by these fan you guys are showing and hooking it up with a temperature controlled switch.
    Post by donivan65 Thu Jul 03, 2008 7:22 pm
    That was the original reason that I put the fan in there,,,,,it was my Hamburger fan,,,,,The carb is vented into the doghouse and when the engine is hot, you smell that gas vaporizing from the heat. But I turn on that fan and it blows the fumes out of the doghouse and cools the engine off,,,the engine will start because it is not flooded out and won't leave a big cloud of black smoke when it starts. It also keeps the Doghouse cool,,,,,Sometimes I have to pull the choke out to start the engine if I leave the fan on too long and it gets too cold,,,,I wouldn't leave home without it.
    Post by donivan65 Mon Jul 07, 2008 4:17 pm
    And back to the never ending Blue No Door Story,,,,,,
    I put those seats that WideLoad gave me in Kentucky into the Van today and took out the coil and points distributor and put in the HEI unit.
    The Blue No Door - Page 2 Repair14
    The Blue No Door - Page 2 Repair15
    The Blue No Door - Page 2 Repair16
    Post by G-Man Mon Jul 07, 2008 6:36 pm
    Nice seats!!!!
    Post by donivan65 Mon Jul 07, 2008 7:05 pm
    so WideLoad,,,,,where are these seats from?????
    Post by Vanish Mon Jul 07, 2008 10:12 pm
    Well I wont Know How to act with out a Remote Coil ... Thanks Don Looks Good !!!!!
    Number of posts : 1388
    Post by wideload Tue Jul 08, 2008 6:09 am
    Those are the orginal seats out of my 67-90. Never did figure out the big round hole in the driver's seat. Was that way when I got the van. wideload
    Post by donivan65 Sat Jul 19, 2008 10:25 pm
    And who is that at the door????
    The Blue No Door - Page 2 Th_Vanishdrive1
    The Blue No Door - Page 2 Th_Vanishdrive2
    The Blue No Door - Page 2 Th_VanishDrive3
    Post by VANagain Sat Jul 19, 2008 11:27 pm
    Nice of you to allow us all to experience this reunion through your videos. All they needed was that sappy "Reunited" song for background music to make the moment complete! Then it would have really brought a tear to my eye! Well, maybe save that for the shot of him driving it home.
    Last edited by VANagain on Sat Jul 19, 2008 11:27 pm; edited 1 time in total (Reason for editing : typo)
    Post by Vanish Sun Jul 20, 2008 1:11 am
    Don..... THANK YOU ............. Wink
    Post by G-Man Tue Jul 22, 2008 4:02 pm
    Vanish that is just too cool!!!!! Great to see you back in a early!!!!
    Post by Vanish Wed Jul 23, 2008 9:15 pm
    You Know those seats that wideLoad give me are Real comfy to sit in !!!!! Just need to take them out to go to the upholstery shop !!!!
    Post by wideload Thu Jul 24, 2008 5:03 am
    Glad they worked out for you Vanish. I never could figure out the big hole in the bottom of the drivers seat. It was that way when I got the 67. Something cut a nice smooth hole but you wouldn't think that it was done on purpose?????? wideload
    Post by donivan65 Thu Jul 24, 2008 1:01 pm
    It probably burned and they cut out the bad spot,,,,,,but I added some foam and sewed another piece over it,,,,,,but they sure are comfortable,,,,,,
    The Blue No Door - Page 2 Nodoor13
    Post by Guest Wed Jul 30, 2008 6:11 am
    yr van look good are those the origal mirrors for that year if not and you have a pic of some can you post it here thanks
    Post by donivan65 Wed Jul 30, 2008 2:39 pm
    The bracket is original but the rectangular mirror heads are not,,,,,I put those on so I could back that cave van up without hitting anything,,,,,,the originals are about a 5" round type with those brackets. And if you want to see mirrors,,,,,look at what we use,,,,,,,,,
    The Blue No Door - Page 2 Th_d221e5da
    Post by donivan65 Wed Aug 20, 2008 1:56 pm
    And back to my tree and the Blue No Door. The tree is finally down and cut up. Vanish brings me a couple of front axles and springs to rebuild and install on the No Door.
    The Blue No Door - Page 2 Tree_017
    The Blue No Door - Page 2 Tree_018
    The Blue No Door - Page 2 Tree_019
    The Blue No Door - Page 2 Tree_020
    The Blue No Door - Page 2 Tree_021
    The Blue No Door - Page 2 Front_10
    The Blue No Door - Page 2 Nodoor10
    The Blue No Door - Page 2 Nodoor11
    Post by savage Wed Aug 20, 2008 2:26 pm
    Thats some big chunks of wood. Probably kind of scarce out there?? Nice job of the front axle & springs,you got the sway bar too. Going to be a sweet driving van when it gets back on the road
    Post by G-Man Wed Aug 20, 2008 6:15 pm
    Vanish are you going to heat the house with all that wood???
    Post by Vanish Wed Aug 20, 2008 6:20 pm
    What can I say Chris .... I LIKE FIRE !!!!!!!! Laughing
      Current date/time is Thu May 16, 2024 9:01 pm
