My carb on my 240 is wore out. Has a ton of play in the throttle shaft. I'm not above rebushing it and a kit,but I wonder if there is a quick route.Anybody have any luck with remans? Any part numbers or advice?
240 carb question.
Re: 240 carb question.
I have an Autolite 1100(?), which is basically the same 1bbl carb my first 170 had. When I needed a replacement, the local fuel specialists only found one in all of western Canada. Cost me about $200 if I recall correctly (IIRC). Might be a rare piece in the PNW too.
If Holleys are available, they usually have slight differences in linkage. Good luck.
I needed a carb for my 240 too and the only place I could find one was ebay, and it still wasn't that easy!
But here are a couple options:
http://cgi.ebay.com/ebaymotors/1966-67-Ford-Truck-240-cu-Nos-Carburetor-/320691015481?pt=Vintage_Car_Truck_Parts_Accessories&hash=item4aaaac8f39
http://cgi.ebay.com/ebaymotors/NEW-63-69-Ford-Holley-Carburetor-240-300-cu-eng-/220833497953?pt=Motors_Car_Truck_Parts_Accessories&hash=item336ab3c361
You can always google the part numbers too to see which models the carb is actually for. I think I ended up getting one that was for 65 - 67 240 ford passenger vehicle man. trans. or something like that. It works great. I was also picky and wanted manual choke, which took longer to find.
When you look up carbs for the 240 not alot shows. But look up Autolite 1100 and you get some hits. I sold out and called Carbtech out here in Tacoma. They said 175 to rebuild it and 25 to rebush it.They have done well by me and others I know. They have a warranty too. Kinda spendy but it will be nice to just file it under finished.And mess with the fun stuff.
