my A108 is barely charging... about 13 volts with the engine revved up... where is the voltage reg located? is it internal to the alt?
1968 A108 - Voltage Regulator?
Re: 1968 A108 - Voltage Regulator?
huh... just found this....
https://vintage-vans.forumotion.com/t17098-votage-regulator-problem
looks like going to a electronic VR is the way to go. Will update.
Got the electronic VR from J&N and it worked like a charm. Charging again... back on the road.
Glad that helped you out!
I'm really pleased with that thing, got rid of my charge/light pulsing as well, I got two and carry a spare with me now.
