My '65 has started randomly blowing the alternator fuse in the fuse block, there's one called "gen/alt" that has a 25 amp fuse in it. It started 3 weeks ago or so and I suspected the electric fan was causing it but it isnt. It blew the fuse pulling out of the driveway yesterday and I stopped right away and changed it. It was working fine until I started to pull out again and it blew again. I changed it out with a 30a and it held until I got done with my stuff and got it home.
Here's the symptoms:
1) The gauge works, if it stops moving I know the fuse is blown.
2) The gauge is reading very high at idle, bouncing between 3/4 and pegged-max on the "charging" side.
3) Just off idle the gauge pegs out on max charging and stays there, this eventually results in blowing the fuse.
I'm not familiar with the amp gauges like this, does this mean the system is "drawing" max amperage or that it's "producing" max amperage?
It starts fine and runs fine but it appears to be producing too much power, I assume because the voltage regulator has gone bad. It was warm to the touch but not hot, I need to pull the cover and see if the "points" are actually working.
My experience with Chevy's is that bad regulators typically resulted no charging at all, not over charging, is over charging common in the early dodges?
Any other tests to do?
If it needs replacing do I get an OEM one or the electronic/solid state one off ebay?
I don't want to drive it like this for the obvious fire hazard related reasons.
Idea's are appreciated!
thanks
