Ive been reading all of the comments and suggestions for dealing with the VR/ Charging and Alternator problems some of you have encountered. This week I began the wiring part of my 67 A100 project. The alternator, one of several that came with the van, has two field wires on it. Looking at the wiring diagram in the Dodge service manual, it shows a single field terminal alt. The VR is a old mechanical type, looks like Napa. My plan is to follow the path that many of you have taken by replacing the VR with a quality electronic VR. What brand / part number is the best one to go with? We dont have a pick a part yard around here, so ill go with a new one. With the VR being replaced, is the two field terminal alt the right application? I may replace the alt at the same time. Is a 60 amp alt the right application also? Needless to say fusible links will be installed also.
Have some question on the starter system also but will post on a seperate thread. Thanks.
