    A108 gauge voltage regulator
    Dragsterbus
    Dragsterbus
    Number of posts : 38
    Registration date : 2011-01-21
    A108 gauge voltage regulator Empty A108 gauge voltage regulator
    Post by Dragsterbus Fri May 06, 2011 3:39 pm
    Hi everyone, Just getting my A108 ready for the road , passed it's MOT and it's registration number arrived today (got '108 in the number too !) BUT my fuel gauge and temp gauge have both gone off the top (Full and HOT !) they were both working fine (new sender unit etc) A friend of mine says there is a voltage regulator for the gauges that takes it down to around 5 volts , my problem is i can't find the pesky thing ! it's not behind the guage cluster, Anyone know where it lives ?
    Thanks for any help
    Wayne
    Number of posts : 3046
    A108 gauge voltage regulator Empty Re: A108 gauge voltage regulator
    Post by RodStRace Fri May 06, 2011 4:12 pm
    Dragsterbus
    Dragsterbus
    Post by Dragsterbus Fri May 06, 2011 4:31 pm
    Thanks for that , I read that someones '65 has the regulator built into the fuel guage , i'll check mine tomorrow and will probably make a new 5 volt external one,
    Thanks for your help
    Wayne
    Dragsterbus
    Dragsterbus
    Post by Dragsterbus Sat May 07, 2011 2:42 pm
    I took out the fuel gauge today and the regulator is built into the guage , i fiddled around with it and it is working again but i will make a modern equivelent this week ,
    Thanks for the help
    Wayne
    Number of posts : 744
    Post by kiwimopar Sat May 07, 2011 3:34 pm
    Dragsterbus wrote:I took out the fuel gauge today and the regulator is built into the guage , i fiddled around with it and it is working again but i will make a modern equivelent this week ,
    Thanks for the help
    Wayne
    Check out my pics at the bottom of the page.
    Don't go opening the fuel gauge if you can help it. Just cut the 12V connection off the fuel gauge, and feed the centre terminal with 5V from a solid state device, can also be used to power your oil & temp gauges.
    LMK if you need an easy diagram to assemble one - 1 x 7805 voltage regulator, 1 x 5-100 mF electrolytic capacitor, heat sink and some wire. Took me about 10 minutes to build once I had the parts.
    Dragsterbus
    Dragsterbus
    Post by Dragsterbus Sat May 07, 2011 3:52 pm
    Hi Kiwimopar , i had the guage apart today , and it now works (not for long i know !) , Yep thats how i was going to do it , just got to wait for a couple of days for the bits to arrive ,
    I did prefer the look of the fuel guage reading full though ha ha, it's back on empty now which isn't so good !
    Thanks for the help
    Cheers
    Wayne
    Post by kiwimopar Sat May 07, 2011 4:04 pm
    Dragsterbus wrote:Hi Kiwimopar , i had the guage apart today , and it now works (not for long i know !) , Yep thats how i was going to do it , just got to wait for a couple of days for the bits to arrive ,
    Thanks for the help
    Cheers
    Wayne
    With the current price of gas, I which my gauge always read FULL as well Rolling Eyes
    Number of posts : 956
    Post by slowflapper Mon May 09, 2011 9:00 am
    heres some part numbers for the external limiters:
    NAPA has the Echlin brand, part number "IR9" for $43.00
    Pep Boys has the Borg Warner R-307 unit for $35.00
    Duralast Wells at auto zone: $38.00 Pn: IRV307
    there's some other info in this thread.
    A100Sportsman
    A100Sportsman
    Number of posts : 156
    Registration date : 2010-10-24
    Post by A100Sportsman Tue May 10, 2011 10:46 am
    The voltage regulator on the A100 gauges is inside the gauge itself. On the Mopar cars it was an external part. For my gauges, I took a cigarette lighter universal power adapter, put it to 5v and wired it into a different inlet on the fuel gauge to bypass the voltage regulator. This is just a temporary fix until I get an external voltage regulator, but it works great Very Happy
      Current date/time is Thu May 09, 2024 8:18 am
