+55
SportVan
NipRing
Scotts_A100
ndjarrett
66 Surf Wagon
sandyvan
southern man
kookykrispy
thatcherworks
mrclean
LiveWire64
sparky
SDEconoTruck
64chevy
wacko
mo_1040
59 posters
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe
    Number of posts : 1046
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Empty Re: Back to......VANagains NEWest 65 Chevy SportVan Deluxe
    Post by VANagain Sun Jul 18, 2010 12:27 am
    Finally, a real good test drive!! Don came to the rescue! Like he told me, things were going the wrong way, getting worse instead of better. And there were too many variables, so we started eliminating some.
    We checked the plugs and two broke in half as we took them out! Bought a new set and left them with the gap they came with: about .045".
    We then put on a Carter carb. They are much simpler than the Rochesters. It ran good but we couldn't test drive it because my tranny's throttle valve cable wouldn't hook to it. We then tried a different Rochester, a newer model than mine. Funny thing, it had a bracket that was easily adapted to hook the TV cable to! We had to Mickey Mouse the choke and a couple other little things that allowed us to take the test drive.
    I'm a happier camper now! Now I've got a lot of things to tidy up. Springs, clips, and wiring to do right. And this week I've got a brand new exhaust manifold coming, so I might try putting my old carb back on just to make sure it was the culprit.
    And, now that my brake light switch is fixed, I was able to hook up the relay that disengages the tranny's torque converter lock to allow it to come out of overdrive when slowing down. It too worked fine on our test drive. One more thing I can check off the list!
    Post by Nightmoves Sun Jul 18, 2010 6:03 am
    What/whose exhaust are you goin with? You changin out the intake too?
    Post by donivan65 Sun Jul 18, 2010 8:43 am
    His exhaust manifold is warped and has broken studs, so he is just getting another stock one,,,,,and the intake is sucking air, so he is just going back to stock. But as for the newly overhauled brake light switch,,,,,it needs to go,,,,,it already spun when I put it on and the lights would not turn off,,,,,,,,it might of spun again going down the road which would account for deactivating the overdrive and the van could be sitting there right now with a dead battery from the brake lights being on,,,,,,,,,,,
    Post by donivan65 Sat Jul 31, 2010 5:55 pm
    Lets see what Rich is doing to his Van again,,,,,,,,,
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Vanaga30
    Number of posts : 1383
    Post by BILLS66 Sat Jul 31, 2010 7:05 pm
    No way serious? Bill
    Post by G-Man Sat Jul 31, 2010 9:18 pm
    That would look over the top on a early
    Post by Nightmoves Sun Aug 01, 2010 2:51 am
    Hey....what happened to 'stock'? heh Thats gonna look so cool on there.
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Empty Carburetors, Man. That's what life is all about.
    Post by VANagain Sun Aug 01, 2010 1:05 pm
    This would look really cool, having 3 carbs on a straight six! But that would be overkill. I've got enough trouble tuning one carb! We took that photo because we were juggling 3 Rochester carbs: my original one (that was acting up), Don's loaner (that cleared up my problems), and a rebuilt one I bought on eBay, which is really a beauty:
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Dscn4410
    Got if from a guy who goes by carb_ologist on eBay. The card that came with it said Mike's Obsolete Auto Parts. I don't know if this carb had been sitting around in this old-time box for years or if it was recently rebuilt but the engine fired up right away and didn't really have to make any adjustments. We took a test drive and it was the best one yet! Lots of power, idles nice, no backfiring. I'm a happy camper!
    The new exhaust mainfold was also a big help. Nice and quiet in the doghouse, finally! This guy still has some like it for sale:
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=140400905304
    It's clever how you can use two or three bolts to hook up the exhaust pipe. My only complaint is that it looks like the heat riser will not drop open with gravity once it's warmed up. But we noticed that higher RPMs will push it open.
    Since the manifold was all nice and clean bare metal, it was a perfect opportunity to give it a nice coating to prevent rusting. I read a lot of good things about POR-15's manifold paint so I went with that. The guy at my local auto body supply showed me the POR-15 catalog and they show three colors to choose from. There's black, gray and a light silver one that would look like aluminum. Their photo was a little deceptive, showed them all lighter than they actually are. But the gray turned out exactly how I wanted it. Looks just like bare cast iron! And it will stay that way, no rust!
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Exhaus10
    This is what I used:
    http://www.por15.com/FACTORY-MANIFOLD-GRAY/productinfo/FMGG/
    And all you need is the 8 ounce can for $18.75. That will actually be enough for two coats on two manifolds. Their instructions are pretty good be leave out a few things. This is what I did, based on what I read from them and online:
    • Washed the manifold with a degreaser.
    • Applied an metal prep, anti-rust solution that has phosphoric acid. Did not rinse with water but washed again with degreaser.
    • Stirred the paint instead of shaking the can (which creates bubbles). And I stirred it before each dip of the brush because there is a lot of metal flake that likes to settle to the bottom.
    • Taped over the lip of the can. They say that if you put the lid back on with this stuff in the lip, you'll never get it open again!
    • Used a small foam paint brush to apply it. Less brush strokes. Put on one heavy coat instead of lots of light coats. Dabbed any runs away. I did all this work at noon out in the sun so the metal would be hot, might help if its pores are open, plus it may have helped it set up and not run. I painted everything except gasket surfaces.
    • Left it out in the sun for the rest of the day.
    • Second coat 24 hours later.
    • It has to dry for another 24 hours before heating it up. It has to be cured at temps of 300 degrees or more. Some guys talk about putting it in the oven but most just put it on the engine and run it. This curing process removes any brush strokes that didn't go away. (I don't see any.)
    • Screwed in all the studs and attached the automatic choke. Choke mounting holes had metric threads.
    • Attached to engine, put everything else on and ran it for about 5 minutes. It really smoked when it got hot! Later I drove it a little, and it still smoked. But the next day when I started it no more smoke. Looks really nice!
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Dscn4411
    Number of posts : 7900
    Post by DanTheVanMan Sun Aug 01, 2010 3:36 pm
    I've been using POR 15 products for years and swear by them. Used them on my Jeep CJ7 restore in 2003 and still holding up great. Using them on the 66 G10 as well. GREAT STUFF!!! cheers
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Qr_cod10
    Post by VANagain Sun Aug 01, 2010 11:59 pm
    Huh oh! An update on the POR-15: it's already pealing off my new exhaust manifold!! What could I have done wrong? It's not big flakes yet but a lot of small cracks where it's starting to lift off. Sad
    Post by donivan65 Mon Aug 02, 2010 9:02 am
    I would think sealer needs to stick to bare metal,,,,,,not phosphoric acid mixed with engine degreaser,,,,,,
    Post by DanTheVanMan Mon Aug 02, 2010 10:25 am
    Metal "Has" to be clean!!!! If there is "ANY" petroleum residue at all of any kind it will crack and peal when it heats up.....
    Post by VANagain Tue Aug 03, 2010 12:31 pm
    So what's the best way to clean steel for painting, especially cast iron that's all bumpy? The paint on my engine block started pealing right away too. Mad
    I didn't use engine degreaser. I've been using PPG DX330 Wax & Grease Remover on every part I paint. Has always worked great except on these cast parts.
    I just read this on a web site: "Use Dawn dishwashing soap to remove the oil and grease on your parts." That sounds like a good idea! Scrub it real good with a brush to remove any oils from the rough parts. Blow it dry afterwards. Then use my degreaser as a final cleaning.
    Post by VANagain Tue Aug 03, 2010 12:59 pm
    I drove my van to the DMV this morning. My longest trip in it yet! When you bring a vehicle in from out of state they need to see it in person. I got there before they opened but the line still extended way out into the parking lot. (Yes, I did try to make an appointment first but they were scheduling about a month out!)
    I didn't have to wait too long to get to the visual inspection:
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Dmv_da10
    They checked the VIN number plate, peeked at the engine, and filled out the form. Just like that, I was through the tough part! The van, bill of sale, and title were all in order!
    Back inside I waited for my number to come up. (Thank goodness I had my iPhone!) Three hours after my arrival I handed them a bunch of money and they gave me my California license plates! 14 years later the old van is legal again!!
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Dmv_li10
    Post by Guest Tue Aug 03, 2010 1:07 pm
    Its good to see your progress! Legal is a big deal, as our vans are definitely not 'off the radar'!
    Congrats!!
    Post by VANagain Sun Aug 08, 2010 12:45 am
    Copenhagenfiend, that is quite a wicked van drawing you've got as your icon!
    Today I took on a little task that snowballed into an all-day job: clearing everything out the back of the van! As I've said before, I love how we are able to store all our spare parts in the back while we work on the project. But now that I can drive the thing, it was time to clear out that mountain of stuff. I made these piles: parts yet to be installed soon, spare parts, parts to sell or give away, and trash.
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Dscn2910
    About halfway through the day I got to the bottom. This is the first time I've been able to see the entire floor! I crawled in there with a leaf blower and blew out the accumulated dirt.
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Dscn2912
    I then spent the rest of the day rounding up other parts from the garage and then really got an inventory of what I've got. Better late than never, I've now got things really organized and should have a lot more luck finding things when I am ready for them. (Plus it helps that a lot of the big stuff has been actually put on the van!)
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Dscn2911
    I made a new to do list (and a to buy list) and made sure all the parts I'm going to need in the near future are close at hand. These will be some fun and fairly easy to complete tasks.
    Post by Nightmoves Sun Aug 08, 2010 2:05 am
    Shazam! Clean floor front to back,Passenger seat mounted,no parts Don can fall into in the back.Now you can look back and say,wow look at all that room.
    It's easy to fill it up as a parts storage though.My downfall is about 1/2 my tool box ends up in the van,and don't return where it's suppose to.
    Looks good back there.Your on a roll.
    Post by G-Man Sun Aug 08, 2010 4:15 am
    Vanagain looks great and alway good to hear another back on the road. Nice job have enjoyed this thread
    Post by donivan65 Tue Aug 17, 2010 5:27 pm
    Next test,,,,,,,,pull my seat out of my 88 Cavalier and let VavAgain try it out for size,,,,,,,
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Vanaga31
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Vanaga32
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Vanaga33
    Post by VANagain Thu Aug 19, 2010 12:45 am
    Don, I appreciate the opportunity to test the fit of a Cavalier/Sunbird seat, especially considering you unbolted it in triple-digit temperature! (That is one nifty digital dash!!)
    Post by donivan65 Sun Sep 05, 2010 8:50 pm
    Ok,,,,,,,Today I go down the mountain from the 90's, towards the coast and its cloud cover into the 70's and me and VanAgain go on our first cruise,,,,,,,,down Highway 101,,,,,,
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Vanaga10
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Vanaga11
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Vanaga12
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Vanaga13
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Vanaga14
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Vanaga16
    Post by Vanish Sun Sep 05, 2010 10:20 pm
    Looks fun ........
    Post by donivan65 Sun Sep 05, 2010 11:18 pm
    Funner than stepping out on my front porch barefooted last week,,,,,,,
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Tree_610
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Empty Cruisin
    Post by VANagain Sun Sep 05, 2010 11:52 pm
    It was a nice day for a cruise. Don got me motivated to leave all the projects at home and hit the road! This was my second long drive in my van, the longest one yet. But I knew Don would be there if anything went wrong. And good thing too -- when I went to pay for my lunch I realized I had left my wallet at home! Luckily Don was there to bail me out!! Smile
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Vancru10
    Back to......VANagains NEWest 65 Chevy SportVan Deluxe - Page 8 Vancru11
    Here are two cruising videos from my vantage point:
    Short Video
    Long Video
    Post by donivan65 Mon Sep 06, 2010 12:01 am
    $7 to bail him out of Subways,,,,,,,,,,I was out in the parking lot when I got his call,,,,,,,,,,,he would of been on his own if he got pulled over for no seat belts or front license plate,,,,,,,,,,or Drivers License,,,,,,
      Current date/time is Sun May 19, 2024 2:43 pm
