My dad has a '64 Falcon Van with the original floor box heater. A couple of years ago I found and NOS heater valve and it's installed. I recently had the heater core flushed, checked for leaks and repaired by a great radiator shop. Hot water is getting to the valve but will not go through. I disconnected the valve and flushed cold water through the core but hot antifreeze will not go through. The core doesn't get warm at all.
I installed a rear heater and it is working great so I know there is plenty of flow through the block and intake lines. Has anyone experienced this problem before? Is it possible that the valve gets hot and swells shut? Are there any other cores that will fit the floor box heater to replace the valve? I am thinking about having another core with an inlet and outlet soldered into place to bypass the valve altogether.
I am just wondering what solutions others have or what suggestions you may have. Thank you in advance.
