Alright G guys, I have a '69 with oil bath breather that the lid is cracked at the mounting flange. I found a paper filter breather assembly online that has a top that looks identical to the oil bath top, except for the hole distance. I'm not familiar with the paper filter style breathers, does the long oval lid section separate from the element housing like the ones on the oil bath housings do? He says it's one piece, it doesn't separate. I'm guessing it's spot welded together. He doesn't have the mounting pad that bolts to the block. Anyone in here have parts they can spare. I'd much rather put the oil bath back on it.
Pic of mine, then pic of paper element housing. Thanks
