    Leaking Windshield Fix?
    Number of posts : 1651
    Leaking Windshield Fix? Empty Leaking Windshield Fix?
    Post by Scott Wed Jul 28, 2021 6:56 am
    Any Ideas?
    I just had the window channel repaired, and the windshield replaced with a new gasket. Now, in the first rain it leaked at the top. I don't want to start right in rusting this new channel, and don't like the water on the dash either.
    I overhead someone at Van Nationals saying the old vans didn't need glue on their window seals, which I don't know why they wouldn't, but I wonder if that the person putting in my window thought the same thing.
    I am hoping I can find a glue / sealer that I can put into a syringe. I should be able to drag the needle between the rubber seal and body, injecting as I pull it across.
    Any idea how to fix this, or something I could use?
    Number of posts : 12189
    Leaking Windshield Fix? Empty Re: Leaking Windshield Fix?
    Post by donivan65 Wed Jul 28, 2021 8:13 am
    Could be water sneaking in from drip rail seam from rear,,,,how about spray soap on gasket and use air or leaf blower on inside to see if you get bubbles on outside to pinpoint problem,,,,,
    Post by savage Wed Jul 28, 2021 9:00 am
    Scott I was told by (older)glass guy, that the windshield gasket was suppose to be installed with Bedding compound(come in tube ) I put in a few, & had to go back & caulk the top (gasket to body)because of leaks. Hope this Help's
    Post by Scott Wed Jul 28, 2021 10:30 am
    I sealed the drip real a while back, but I will check it. I was a little skeptical of it in a few places. Also, the body shop was doing some welding on the top of the rear door frame, maybe they overheated the drip rail seem sealer.
    Plan B is the calk along the top windshield seam.
    Oh, that and I contacted the body shop that put it in to see what they say. Really it should be on them to fix, but I am not happy with their work so far and don't want to take it back.
    Thanks for your help..
    Post by donivan65 Wed Jul 28, 2021 12:18 pm
    You using the correct gasket,,,,you think the water runs down the glass gets under the glass and up onto the dash,,,,,
    Leaking Windshield Fix? Dscn0137
    Leaking Windshield Fix? Dscn0138
    Leaking Windshield Fix? Dscn0139
    savage likes this post
    odysseus1962
    odysseus1962
    Number of posts : 3
    Registration date : 2015-01-03
    Post by odysseus1962 Mon Aug 09, 2021 6:47 pm
    Pretty sure there was bedding in there. That primordial ooze, black butyl stuff should do it. You can get it at NAPA. Glue might cause some grief, I've heard, because these bodies flex a lot more than the new vehicles, and you could snap the glass.
      Current date/time is Mon Oct 02, 2023 8:52 am
