    4L60e install
    StuartG
    StuartG
    Number of posts : 28
    Registration date : 2019-05-10
    4L60e install Empty 4L60e install
    Post by StuartG Sat Nov 28, 2020 12:13 pm
    Are there any problems fitting a 4L60e in a 64’ first gen g-10
    behind a 250 ??? Any cutting needed? Original crossmember need to be cut out?
    Any help much appreciated
    Thanks
    Number of posts : 890
    4L60e install Empty Re: 4L60e install
    Post by jrinaman Tue Dec 01, 2020 9:54 am
    the 4l60 or 700r4 might have issues with top of bellhousing hitting rear of doghouse. in a second gen, there is a bump in doghouse to fit. i had already lowered my engine/trans to fit the 292 so i had no issues when i had the 700r4 but was forewarned it would not fit. during installing, i could see it would be tight if i hadnt lowered it. i do not think it would take much to get it to fit but it will be a tight fit or need minor adjustments to fit.
    dix likes this post
    Number of posts : 12254
    Post by donivan65 Thu Dec 03, 2020 8:37 pm
    We have installed  some 700R4 trans in 1st Gens with 6 cylinder engines,,,,Rich made a fancy hanging one, I go for a 3rd Gen crossmember.....
    https://vintage-vans.forumotion.com/t1038-back-to-vanagains-newest-65-chevy-sportvan-deluxe
    Post by donivan65 Thu Dec 03, 2020 8:45 pm
    Post by jrinaman Fri Dec 04, 2020 7:06 am
    4L60e install 14400512
    i made a similar hanger for mine, didnt work out so well.
    Post by donivan65 Fri Dec 04, 2020 11:16 am
    .......In my book, you learn more by seeing what didnt work so you know what direction to go in..............
    Post by jrinaman Fri Dec 04, 2020 11:44 am
    donivan65 wrote:.......In my book, you learn more by seeing what didnt work so you know what direction to go in..............
      an education is expensive, weather you get it in college or learn threw your own experiences/mistakes. after towing the van, then the camper 400 miles home and buying another transmission, i fabbed a hanger that looped around the trans and used the factory tranny mount on the bottom. that one swung side to side and after making a couple different braces (both failed!), i just spent the $100 bucks on the speedway crossmember!!4L60e install Img_2038
      Current date/time is Fri Jan 24, 2025 11:14 am
