Intake line
Baczek- Number of posts : 48
Registration date : 2015-05-10
Intake line
jrdunn96- Number of posts : 688
Re: Intake line
The Falcon Six's "log intake" doesn't have coolant running through it. I'm not sure if mine has one, but I'm almost sure it would have to be a vacuum line. I suspect it might be for a brake booster. Just my $.02.
Jim
Jim
Re: Intake line
Could also run to the PCV valve. How is your valve cover vented?
- Number of posts : 2082
Re: Intake line
Yeah, if you have a PCV connection on the carb base or carb adapter you won't need that hole. As said, it is a vacuum port. You may need it for C4 trans modulator or a brake booster ect.
Re: Intake line
Re: Intake line
It is vented, it draws air through holes in the perimeter of the bottom of the fill cap.
Old Skool- Econoline Guru
- Number of posts : 1306
Re: Intake line
Usually brake boosters use a larger diameter hose as it needs air (cfm) as in vacuum. ALL small sixes have the log intake of which it would be impossible to get water in there or kill the motor. I would suspect that is as simple as for an automatic transmission as Seth said.
Its pretty obvious on the 1st picture that the person is using the water heated base plate under the carb and so why would there also be a cooling line at the vacuum line ???? Follow the water heater hose coming from the water pump and up to the carb....
OLDSKOOL
OLDSKOOL
