+5
gfleduc
AzDon
boogieman
Skulptorchaz
9 posters
    Door latch rods are extremely noisey, Fixes???
    Skulptorchaz
    Skulptorchaz
    Number of posts : 326
    Door latch rods are extremely noisey, Fixes???  Empty Door latch rods are extremely noisey, Fixes???
    Post by Skulptorchaz Wed Jan 18, 2017 8:13 am
    As I put out in the General Discussion Forum, I took my van out for a maiden voyage and it had a INCREDIBLE noise in the back. After checking it out, here it was the rods that latch the doors - top and bottom - that, I guess, wallowed out in there. I need to get into them and see what it is exactly but I was wondering if there was some sort of "fix" or kit that we can get? If I have to fab something, no big deal but, a lot of times it just as easy to get the replacement parts (if there are any).
    Thanks guys,
    Chaz
    boogieman
    boogieman
    Number of posts : 69
    Registration date : 2015-10-12
    Door latch rods are extremely noisey, Fixes???  Empty Re: Door latch rods are extremely noisey, Fixes???
    Post by boogieman Wed Jan 18, 2017 8:39 am
    not the most elegant fix, but i took a ball peen and shmushed the door onto the slide latches a bit..it worked well even without replacing the weatherstripping which i need to do...
    Skulptorchaz
    Skulptorchaz
    Post by Skulptorchaz Wed Jan 18, 2017 11:39 am
    Interesting..... scratch
    Number of posts : 1412
    Post by Vantasia Wed Jan 18, 2017 12:02 pm
    I had the same issue.  First, you should know that the rods rattled from the factory so there was a service bulletin issued with spring steel clips sent to the dealers to insert into the striker plates to hold the rods tight at the top and bottom.  But almost everyone reports they are long gone or their van never got the recall back in the day, and they are missing or rusted and broken off.  Someone was selling reproduction clips over at VCVC forum. Might want to check. Two things I did, make small clips from aluminum or steel and attach them to the striker plates to tighten up the square holes for the rods, I used epoxy to hold some aluminum L shaped shims in place and greased them up. This also tightens the doors which in turn helps reduce the rattle!  Second, wrap the rods inside the doors with something to cushion them  I used plastic wire wrap, scraps of foam rubber, anything that works.  That will stop the rods from rattling when you drive around but still allow them to slide up and down when you open the door handles.
    Skulptorchaz
    Skulptorchaz
    Post by Skulptorchaz Wed Jan 18, 2017 12:28 pm
    Thanks Vantasia.
    I can fab up some stuff but I was hoping there was a "fix".
    Thanks a bunch!!
    Chaz
    Post by Guest Wed Jan 18, 2017 3:48 pm
    On this topic... I had trouble with the foot pulling up and out of the hole when opened the door and I would have to reach down in a put it back in place. I put about a 6 or 8 in piece of heater hose over the rod and forced it slightly over the foot (latchy thing that sticks out) which gives it enough movement but keeps it straight enough to go back in the hole without falling out. Then I taped it with duct tape at the top of the hose. It will also keep the rod from falling out of the door if the top clip breaks.
    Skulptorchaz
    Skulptorchaz
    Post by Skulptorchaz Thu Jan 19, 2017 8:07 am
    I was thinking about hose as well. I will look at that.
    I was also thinking of some medium density foam with a slice in it for the rod and push/wedge it in around the rod, holding it still.
    Thanks!!!!
    Chaz
    AzDon
    AzDon
    Number of posts : 742
    Post by AzDon Thu Jan 19, 2017 12:18 pm
    My 66 van (the one in the avatar) had the outside handles shaved..... On the primary (front) side door, I had the upper/lower latches and rods removed so that only the spring loaded primary latch was operational....Basically, I just shut it the same as a front door... It never popped open or failed to stay tightly shut and aligned.... Inside, I fabbed a pull rod setup from the handle to the front of the door so I could reach the release through the passenger door..... I am probably going to do the same to my current van....
    gfleduc
    gfleduc
    Number of posts : 367
    Door latch rods are extremely noisey, Fixes???  Empty Door rattle clips
    Post by gfleduc Fri Jan 20, 2017 7:01 pm
    Just FYI as part of the tread and noted by Vantasia
    Chevy Service Bulletin DR #679
    Door latch rods are extremely noisey, Fixes???  Door_c10
    Number of posts : 1778
    Post by m1dadio Fri Jan 20, 2017 8:01 pm
    Also if the hinges are warn and the bumper blocks are not tight it could be the whole door bouncing. When I first  put my van on the road the doors rattled so bad it sounded like a Chinese New years Parade.
    Door latch rods are extremely noisey, Fixes???  Img_2012
    Door latch rods are extremely noisey, Fixes???  Img_2010
    Door latch rods are extremely noisey, Fixes???  Img_2013
    Door latch rods are extremely noisey, Fixes???  Img_2011
    Door latch rods are extremely noisey, Fixes???  Img_2014
    These blocks are to suport the door when closed to stop them bouncing and killing the hinge pins and latches.
    Post by vanny Sat Jan 21, 2017 2:27 pm
    Looks like a Great Idea, M1! Very Happy
    Skulptorchaz
    Skulptorchaz
    Post by Skulptorchaz Sat Jan 21, 2017 6:06 pm
    Thanks , M1.
    I checked the hinges and they are tight but, the rubbers are hard as Chinese arithmetic. Where can I get these???
    Thanks,
    Chaz
    Post by m1dadio Tue Jan 24, 2017 6:13 pm
    I bought these from Lucky Chuky who was making them. I think they are also repoped for the corvan. Check the Clarks corvair catalog
    Skulptorchaz
    Skulptorchaz
    Post by Skulptorchaz Tue Jan 24, 2017 6:22 pm
    Thanks bud. I'll see if I can find them!
    I appreciate it!!
    chaz
    Skulptorchaz
    Skulptorchaz
    Post by Skulptorchaz Tue Jan 24, 2017 6:27 pm
    Number of posts : 2086
    Post by Seth G Tue Jan 24, 2017 7:17 pm
    It's tragic if they make these parts for the corvan and not the Chevy/GMC van, there's such a huge market for corvans tho Wink
    Skulptorchaz
    Skulptorchaz
    Post by Skulptorchaz Wed Jan 25, 2017 12:06 pm
    Yeah, but maybe one of these days these baby's will bring the money a 23 window micro bus does. cheers lolololol lol!
    But as for the bumpers, I think the ones at the bottom of the page on the right will work. They don't say how thick they are but there are shims for them.
    Skulptorchaz
    Skulptorchaz
    Post by Skulptorchaz Wed Feb 01, 2017 6:23 am
    Update:
    Just to see if it will work, I bought a strip of about 2'' square foam for sealing under house air conditioners. I cut it in sections and put one around each "bar" in the doors. It keeps them from rattling when I wiggle the door but I haven't had it on the road yet (I'm finishing up my belly pan.)
    These are only temporary as I am afraid they will hold moisture. If they end up being a final fix, I think I would rather have a foam type material I have seen in packaging. NOT Styrofoam but almost like a cross between foam rubber and Styrofoam. It's kind of "rough" and still springs back like foam rubber. Sorry, I just don't know the name.
    I also am trying Vantasia's idea with the aluminum (I used zinc as I had it in the right thickness) on the tops of the two rear doors. I could not get foam in there along side of the windows.
    Thanks for all the ideas and help guys.
    Chaz
    Number of posts : 801
    Post by panelmanrd Wed Feb 01, 2017 6:51 am
    what worked for me was to take bubble wrap, the small bubble type
    and wrap around the rod 2 or 3 times tie it in place with zip tie then
    push the wrap up into the cavity where the rod goes into the door, this
    will not keep moisture and will stop the rattling of the rods and if you
    push the wrapping up far enough no one can see it or hear it, I have used
    this trick to two early vans with awesome results.
      Current date/time is Thu May 02, 2024 6:39 am
