    Back-up lamp switch
    dannyeven
    dannyeven
    Number of posts : 6
    Registration date : 2015-02-23
    Back-up lamp switch Empty Back-up lamp switch
    Post by dannyeven Fri Jan 13, 2017 4:05 pm
    Hello all. Can anyone tell me the location of the back-up lamp switch on a '68 Dodge A108? Reverse lights are out and the bulbs are fine. Thanks.
    busman78
    busman78
    Number of posts : 483
    Back-up lamp switch Empty Re: Back-up lamp switch
    Post by busman78 Fri Jan 13, 2017 4:35 pm
    If it is an automatic the switch is on the transmission, on mine which is a 70 trans reverse is part of the neutral safety switch (three wire).
    dannyeven
    dannyeven
    Number of posts : 6
    Post by dannyeven Fri Jan 13, 2017 5:27 pm
    It is an automatic, yes. Thanks for your help.
    Dan Scully
    Dan Scully
    Number of posts : 258
    Post by Dan Scully Fri Jan 13, 2017 5:41 pm
    Unless it has been changed 68 still uses the single pin neutral safety switch. The back up light switch on 68 is on the shifter behind the dash. You can change to a 3 pin switch but requires some internal changes to the transmission.
    dannyeven
    dannyeven
    Number of posts : 6
    Post by dannyeven Fri Jan 13, 2017 10:00 pm
    Thanks Dan, you're right. Only a single pin on the 727. I'll dig behind the shifter this weekend. Much appreciated.
    Dan Scully
    Dan Scully
    Back-up lamp switch Empty Switch
    Post by Dan Scully Fri Jan 13, 2017 11:59 pm
    Here is a pic.
        Back-up lamp switch 20170111
      Current date/time is Sat Jan 18, 2025 7:54 pm
