    back-up lamp switch
    Surfer Van
    Surfer Van
    Number of posts : 2
    Registration date : 2014-11-25
    back-up lamp switch Empty back-up lamp switch
    Post by Surfer Van Sun Jun 09, 2019 4:11 pm
    Hello all.
    Can anyone tell me the location of the back-up lamp switch on a '67 Chevy Sportvan? Reverse lights are out and the bulbs are fine.
    How can i proof that the switch is fine?
    Thanks
    Number of posts : 14778
    back-up lamp switch Empty Re: back-up lamp switch
    Post by vanny Sun Jun 09, 2019 6:05 pm
    Here is a link to some 2nd Gen Wiring diagrams https://vintage-vans.forumotion.com/t25631-second-gen-wiring-diagram
    If you would like to see some other info, you can use the search tab at the top of the page and search on backup... Hope this helps.
    Number of posts : 12234
    Post by donivan65 Sun Jun 09, 2019 9:20 pm
    Is the fuse good,,,,,,,,,is it a manual transmission with this switch connected to the trans linkage?
    back-up lamp switch Dscn0810
    Surfer Van
    Surfer Van
    Number of posts : 2
    Post by Surfer Van Tue Jun 11, 2019 4:17 pm
    Thank you very much to vanny!
    @donivan65, the fuse is ok. It's a power glide transmission. There is a switch with four wires. I don't know, how I can test it.
    Other question, is the wire for the back-up light connected with the steering column?
    Post by donivan65 Tue Jun 11, 2019 5:05 pm
    That 4 wire switch is the safety neutral and back up light switch on our primitive vans,,,,,unless some has,,,,,,,,,improvised,,,,,,over the past 50 years, purple wires are for the starter,,,,one gets its juice from the ignition switch when you turn key to START,  if the switch sees that the trans is in Park or Neutral, it sends juice to the starter solenoid to crank the engine,,,,,,then the Light Green wires work the same way,,,,one has juice from the fuse and if the switch sees that the trans is in Reverse it sends that juice to the back up lights,,,,but it probably has to go through the connector behind the left rear tail light to get to the back up light wires,,,,,,so get a 12 volt test light or volt meter,,,,see if you get voltage with the key on at one of those light green wires at the switch connector,,,,if you do, jump the 2 light green wires together, that should turn on the back up lights,,,,,see what you find, then we can talk more,,,,,,also,,,is that switch hooked up with a little rod connected to the shift rod? does that van start in Drive or Low?
    Rick's 66 Chevy Van
    Rick's 66 Chevy Van
    Number of posts : 331
    back-up lamp switch Empty knowlege
    Post by Rick's 66 Chevy Van Mon Jul 01, 2019 6:27 pm
    Don you need too put the knowledge you have on our vans on video or paperback so we will always have it with pictures of course
    Rick's 66 Chevy Van
    Rick's 66 Chevy Van
    Post by Rick's 66 Chevy Van Mon Jul 01, 2019 6:30 pm
    back-up lamp switch 20170712
    back-up lamp switch 20170713
      Current date/time is Thu Sep 19, 2024 1:05 am
