    wiring diagram for ford E100 pick-up
    Nieuwlaat
    Nieuwlaat
    Number of posts : 13
    Registration date : 2016-12-13
    wiring diagram for ford E100 pick-up Empty wiring diagram for ford E100 pick-up
    Post by Nieuwlaat Tue Dec 13, 2016 10:28 am
    Two weeks ago I bought a 1963 Ford Econoline E100 pick-up truck.
    Unfortunately I face problems with the light and I cannot solve them.
    Maybe some of the forummembers can help me with a wiring diagram or tell me where I can find one.
    Number of posts : 12245
    wiring diagram for ford E100 pick-up Empty Re: wiring diagram for ford E100 pick-up
    Post by donivan65 Tue Dec 13, 2016 11:25 am
    ,,,,,,any particular section that you are having problems with?,,,,,,,,headlights, parking lights, brake lights, tail lights , turn signals, dash lights or dome lights?
    Nieuwlaat
    Nieuwlaat
    Post by Nieuwlaat Tue Dec 13, 2016 12:27 pm
    I have problems with the left tail light, brake light and turn light
    Carl
    Number of posts : 143
    wiring diagram for ford E100 pick-up Empty wiring diagram for ford E-100 pick-up
    Post by Carl Tue Dec 13, 2016 12:56 pm
    www.vintage-vans.com/ford_parts_links.html -scroll down to 1963 wiring diagram -but the 67 diagrams clearer
    Nieuwlaat
    Nieuwlaat
    Post by Nieuwlaat Tue Dec 13, 2016 1:17 pm
    I think this will help;
    Thank you very much.
    Number of posts : 691
    Post by jrdunn96 Tue Dec 13, 2016 4:08 pm
    Welcome! and best of luck.
    Post by donivan65 Tue Dec 13, 2016 4:44 pm
    IF,,,,,,,,you think the bulb is good,,,,,you can check for a bad ground by taking a 12 volt test light, hooking it to ground,,,,,,,turn on the tail lights and Left turn signal, touch the test light to the bulb base,,, if it lights, you got a bad ground,,,, so both the the right and the left front turn signals flash and the right rear tail light works?
    Nieuwlaat
    Nieuwlaat
    Post by Nieuwlaat Wed Dec 14, 2016 1:22 am
    That's what the mechanic did but still the left tail light does not work.
    Now with the wiring diagram he will try to find out what the problem is.
    Thanks
    Old Skool
    Number of posts : 1306
    Post by Old Skool Wed Dec 14, 2016 6:15 pm
    More than likely the turn unit is messed up as thats the usual culprit for your issue,,
    vic
    Nieuwlaat
    Nieuwlaat
    Post by Nieuwlaat Thu Dec 15, 2016 1:16 am
    I will ask the mechanic to check on that.
    We are really desperate because up til now we cannot solve the problem.
      Current date/time is Sun Nov 17, 2024 6:20 am
