(includes vehicles with antique plates)
They pull your E brake on. They put your van in gear, They apply the accelerator pedal until the engine reaches 1000 - 1300 rpms. They hold it there for a couple of seconds. Then let off the accelerator pedal. If your van/vehicle moves you fail.
I've had my van for over 20 years now and have always had trouble getting a sticker in Massachusetts because my E brake will not hold my van at 1000 - 1300 rpms. My E brake WILL HOLD parked on a hill or anywhere......it just wont hold when the accelerator is applied. All my E brake cables are new, The brake pads are good, I took the rear brakes completely apart cleaned and inspected everything. nothings out of the ordinary. E brakes adjusted properly. Nothing seems to be wrong with my E brake.
I guess my question is...... Are the E brakes in 1st and 2nd generation vans suppose to hold when you apply the accelerator pedal? Are they designed to do that? Will your E Brake hold your van from moving at 1000 - 1300 rpms?
My vans a 1968 GMC Handi Van with a Chevy 350 engine, TH350 auto trans, 411 gears in the rear end.
