+32
gfleduc
dutchman101
sweetvan
retrogeek
SteelyVan
divisionbrewing
66BC
whalemstr
richie61
busman78
kaz
Denton
Rick's 66 Chevy Van
36 posters
    GMC Jacke's van
    Number of posts : 940
    GMC Jacke's van - Page 30 Empty Re: GMC Jacke's van
    Post by JackeFriend Mon Feb 11, 2019 12:30 pm
    GMC Jacke's van - Page 30 My_hor10
    My beautiful horn ring and cap... the horn ring has no cracks! It really does not need to be chromed...
    but it will be just so I can kiss it good night each and every evening. I AM VERY HAPPY!!
    Very Happy bounce bounce bounce bounce bounce bounce bounce bounce bounce Cool
    Number of posts : 672
    Post by samsvan Mon Feb 11, 2019 4:34 pm
    You might as well gold plate it to match your van.
    Number of posts : 14778
    Post by vanny Mon Feb 11, 2019 4:46 pm
    Number of posts : 698
    Post by Russell Mon Feb 11, 2019 7:07 pm
    samsvan wrote:You might as well gold plate it to match your van.
    That would look Sweet! Good idea.
    Post by JackeFriend Mon Feb 11, 2019 8:19 pm
    I did think of gold leaf... but that is too much temptation for would be thieves. I would be worried and would need to hire a guard to watch my gold ring. LOL But I did consider it!
    I am buying a hard case to protect it in shipping to and fro as I am sending it out to Utah this week.
    The ring really would be acceptable... but the cap needs chrome. That would then make the ring look like crap. So get them both done. Smile
    Post by JackeFriend Wed Feb 13, 2019 1:12 pm
    GMC Jacke's van - Page 30 Pionee10
    I bought a Vintage New Pioneer 8 track Am/FM stereo for my van! I think it will look cool playing an 8 track tape. I bought a few good ones... LedZepp, Pink Floyd, CCR, Steeley Dan. But it does have a radio too. Next project!
    Post by vanny Wed Feb 13, 2019 5:07 pm
    Better have a piece of cardboard you can tuck under one side of the 8-track tape in case it's not playing right... lol! You're a Class Act, Jacke! Great taste in music, too! cheers
    Post by JackeFriend Wed Feb 13, 2019 7:40 pm
    vanny wrote:Better have a piece of cardboard you can tuck under one side of the 8-track tape in case it's not playing right... lol! You're a Class Act, Jacke! Great taste in music, too! cheers
    Well thanks Paul. I enjoy making my time machine work for me. I have a pack of matches ready for the 8 track tape wobble! I actually bought some brand new 8 track tapes too. Just a few to make the dream seem real. New 8 track tape deck, new 8 track Led Zeppelin tape. What could be better? Oh ya my HORN RING!!!! cheers
    Post by JackeFriend Thu Feb 14, 2019 2:43 pm
    GMC Jacke's van - Page 30 A1sway11
    So when I had the rear sway bar installed, I had a brake shop do it. Evidently they had not an idea about the links needing to be at 90 degrees, in picture maybe 60 degrees. The sway bar cups had a angle to them, I did not realize that would result in a possible bind as the shock go up and down. But it makes sense now of coarse. I have not driven but 10 miles at the most since I had the rear sway bar put on the van. I will need to remove the cups have them heated and bent until the angles out. I am sure glad another vanner decided to take a closer look at my posts about the sway bars. Joyride probable saved me some trouble if not worse! Thanks!!
    I asked Don about it he agreed. But also let me know to change my rusty brake lines! Thanks to Donn as well!! Cause the stupid brake man did not mention it... need a new brake man.
    Post by vanny Thu Feb 14, 2019 4:14 pm
    Kudos to Joyride and Donivan for helping a vanner avoid potential danger. Great people on this site and that's what makes vanners so cool...having each other's back when someone needs their assistance! cheers cheers cheers
    Post by JackeFriend Wed Feb 20, 2019 9:05 am
    So amazingly I was able to get all the gauges and blinkers working. I am now trying to locate the ground wire for the dome light. It has constant power? Although both wires are present there is No ground, I have to locate it in the snarl of wires, to get the dome light ground wire connected. I have two original dome lights plus an old glass light for the back as a courtesy light lower. Should be plenty of light with three. I have a LED small panel in the old glass light it really is bright. Hopefully pictures to follow today's work!
    Post by Russell Wed Feb 20, 2019 8:11 pm
    JackeFriend wrote:So amazingly I was able to get all the gauges and blinkers working. I am now trying to locate the ground wire for the dome light. It has constant power? Although both wires are present there is No ground, I have to locate it in the snarl of wires, to get the dome light ground wire connected. I have two original dome lights plus an old glass light for the back as a courtesy light lower. Should be plenty of light with three. I have a LED small panel in the old glass light it really is bright. Hopefully pictures to follow today's work!
    I may be wrong but I think the headlight switch is the power for the lights when turned all the way till it clicks? That should send the power to the lights? The ground should make contact through the screws that mount the light to the body?
    Someone may have changed some wiring at some point from the switch, Mine has different wiring added in the roof to control the front and back differently.
    Post by JackeFriend Fri Feb 22, 2019 11:56 am
    JackeFriend wrote:I am going to restore a deluxe steering wheel for Russell. I am in between electrical projects waiting for parts. So, I wanted to keep my hands busy.
    This wheel has some big chips which mine did not when I did that restoration. So I will have some new challenges ahead. Last picture is after I have just started the first rough sand to get to the base black plastic. Next will be file file file into those cracks, get them open and ready for holding the repair. Gotta make it worse before it can get better.
    I will post some pictures as I go through the process.
    GMC Jacke's van - Page 30 Repair11
    GMC Jacke's van - Page 30 Repair12
    GMC Jacke's van - Page 30 Repair13
    GMC Jacke's van - Page 30 Repair10
    GMC Jacke's van - Page 30 Repair14
    Here is the first coat of primer, just need to do some final file work and wet sand! What do you guys think!?
    GMC Jacke's van - Page 30 Retore10
    Russell your wheel is almost ready cheers
    GMC Jacke's van - Page 30 Wheel510
    GMC Jacke's van - Page 30 Wheel610
    GMC Jacke's van - Page 30 Wheel810
    Wet sanding done! Ready for Russell
    Post by samsvan Fri Feb 22, 2019 12:41 pm
    What did you fill those missing chunks with?
    Post by JackeFriend Fri Feb 22, 2019 1:56 pm
    samsvan wrote:What did you fill those missing chunks with?
    I used Epoxy PC-7 from Eastwood I had purchased the restoration kit when I restored mine.
    Post by samsvan Fri Feb 22, 2019 4:14 pm
    Looks great. Nice counter top too.
    Number of posts : 691
    Post by jrdunn96 Fri Feb 22, 2019 6:16 pm
    Looks great Jacke!
    Post by Russell Fri Feb 22, 2019 9:44 pm
    Very nice!
    Post by JackeFriend Sun Feb 24, 2019 11:45 am
    Wet sanding done! Ready for Russell Very Happy
    Post by vanny Mon Feb 25, 2019 5:43 am
    Nice job Jacke! Lots of work there but looks like it paid off big time!
    Post by JackeFriend Tue Feb 26, 2019 9:19 am
    Thanks guys, I did my best! Today Russell is picking up his wheel. I can't wait to see it when he does the painting. It should look good in his pretty newly painted van. Smile
    Post by JackeFriend Sat Mar 02, 2019 7:29 pm
    I got the switch in for the dome lights. It is nice having actual dome lights front and rear. I still have to add one courtesy light down lower in the back area by the sofa and table.
    I am getting everything done to have working gauges, lights etc. I still need to get the gas tank to register right. It pegs to full... I have been told the ground wire may be bad, but it could be the sending wire? I have checked each to no avail because the gauge does not work. Each was ok when checked. I found a Fuel line wire which the previous owner did not bother to install when the did the wiring switch. So maybe the old wire is bad? In any case I just add gas to be sure I don't run out... small things make big differences. Wink
    Post by JackeFriend Sat Mar 09, 2019 5:54 pm
    Today I started the antenna install. I was apprehensive doing it by myself, but everyone was busy and I needed to get the task going. So I did get everything lined up and I drilled out the majority of the three 1"
    holes, drill the 1/2" hole through the plenum. But I had to quite I will get at it tomorrow with my dremel. Here are the progress photos...
    GMC Jacke's van - Page 30 Antenn11
    GMC Jacke's van - Page 30 Antenn12
    GMC Jacke's van - Page 30 Antenn13
    Post by vanny Sat Mar 09, 2019 7:30 pm
    Looks like you've got it under control, Jacke...you go girl!!! cheers How was it reading those backwards instructions??? lol!
    Post by Russell Sat Mar 09, 2019 9:07 pm
    Good start, your half way there. Next you'll be cutting open the roof for a skylight?
      Current date/time is Mon Nov 18, 2024 5:32 am
